| Literati914 |
Jun 11 2019, 10:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm gonna order the following items to convert over to an electric windshield washer system, but have some questions about the washer stalk on the column. With the stock set up, how many speeds are there for the wiper action? Is it JUST low and hi only, or is there a middle speed too? (too many years since my last 914 to remember, and it hardly ever rains, so..) Also, is there an intermittent action (I doubt), and is there a way to add it? Same question with the replacement stalk I'm considering (see link)?
https://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G and https://www.ebay.com/itm/BRAND-NEW-WINDSHIE...scAAOSw5ZBWPTnf . |
| SirAndy |
Jun 11 2019, 11:28 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,487 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Also, is there an intermittent action (I doubt), and is there a way to add it? Yes, there was an optional intermittent relay and wiring harness for later cars. It simply mounts in-line with the current wiring, no cutting needed. Do a search here for "intermittent", there are several threads about it. I show the location of the relay (socket) in this tech article: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/bye1.gif) |
| Literati914 |
Jun 11 2019, 12:35 PM
.. Yes, there was an optional intermittent relay and wiring harness for later cars. It simply mounts in-line with the current wiring, no cutting needed. .. Thanks Andy. So, when adding this relay, how does your interaction with the stalk change? Up for intermittent, down..? Ok, you did suggest searching intermittent - the answers are probably there - I'll look again. Good write-up, BTW. Thanks. |
| SirAndy |
Jun 11 2019, 12:48 PM
So, when adding this relay, how does your interaction with the stalk change? Up for intermittent, down..? Later columns have the internals for the intermittent already built in. All you have to do (after installing the extra harness and relay) is to break off a small plastic tab to allow the stalk to go down one more position to engage the intermittent circuit. (IMG:style_emoticons/default/smile.gif) |
| Literati914 |
Jun 11 2019, 02:00 PM
Thanks Andy (IMG:style_emoticons/default/beerchug.gif)
| Valy |
Jun 11 2019, 06:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
That switch is described as 6 pin connector but the picture shows 5 pins, missing the contact for the intermittent relay. Please call Cip1 and ask. I have a correct switch from them but can't find the correct listing now.
The external black wire is for the electric pump. No need to add an external switch and drill more holes. Take the pneumatic pipes off and reroute the tubes directly from the pump to the jets. If you want the intermittent relay, look for the same switch with 6 pins in the connector. The nice thing about the intermittent relay is that it will trigger your wipers for few seconds when you activate the pump. |
| Valy |
Jun 11 2019, 06:59 PM
Found it!
Take a look here for all the info you need. http://www.914world.com/bbs2/index.php?s=&...t&p=1620396 Again, the switch should be the right one but the picture doesn't match the description. You need 6 pins plus the external black wire. |
| porschetub |
Jun 11 2019, 08:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,131 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'am pretty sure I ran a spare wire for my pump trigger to the relay I fitted,I cant remember if it was earth to the relay,I do remember I powered the relay of the fuseboard so would think the wire was an earth.
I see the pump shown is a knock-off by auction description anyway (IMG:style_emoticons/default/confused24.gif) ,the original is a 911 part and not expensive last time I checked,I used a generic VW one that works fine only cause I had in on hand. The OP must make sure the filler cap is blocked off but vented with a small hole. This is a "must do" if you have a 6 cyl with front cooler and spacesaver,in my case no cooler but wanted to drop some weight,plan is to move airpump/tools and alloy wheel to the rear. |
| Literati914 |
Jun 12 2019, 03:02 PM
.. If you want the intermittent relay, look for the same switch with 6 pins in the connector. The nice thing about the intermittent relay is that it will trigger your wipers for few seconds when you activate the pump. This is key info I've been looking to understand, thanks. Found it! Take a look here for all the info you need. http://www.914world.com/bbs2/index.php?s=&...t&p=1620396 Again, the switch should be the right one but the picture doesn't match the description. You need 6 pins plus the external black wire. So, this leaves me a bit confused still.. since your #12 post (in that thread) is a link to the very same lever/switch that I originally posted in this post... and thanks for pointing out that it only shows 5 pins. I sent a note to Cip1 but have not heard back from them. Interesting too, is that their description makes a comment on some models using 4 pin and some using 6 pin - however theirs is 5 !?!?!?!? |
| Valy |
Jun 12 2019, 04:36 PM
There are 4, 5 and 6 pins versions.
I revisited my install so I have to correct myself. You want the 5 pins and that is the correct listing. Sorry for the confusion. |
| FlacaProductions |
Jun 12 2019, 06:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,249 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
So I'm looking at doing this conversion as well and already have the intermittent relay as factory. I also was planning on using the Carmagic washer conversion button (http://carmagic.us/washer.html) but i'm wondering if I'm just better off getting a repro from Cip1 and do it this way...thoughts?
I'm going to be in the column anyway as my signals don't cancel (but I found the W spring on the floor so it may just be that but i'm betting one of the tabs broke off - so maybe "while I'm in there") |
| Literati914 |
Jun 12 2019, 10:25 PM
..I also was planning on using the Carmagic washer conversion button .. but i'm wondering if I'm just better off getting a repro from Cip1 and do it this way...thoughts? I considered that too but the money's not much different with the repro lever from Cip1 - and the new lever will help freshen up the general look/feel of my interior. |
| Literati914 |
Jun 12 2019, 10:27 PM
.. You want the 5 pins and that is the correct listing. Sorry for the confusion. Great! 'cause this is the answer I got from Cip: "...The connector itself has 5 pins and the pump wire is considered the 6th pin. Bill D. - CIP1.com California Import Parts Ltd." I'm placing my order, thanks for the help! |
| FlacaProductions |
Jun 13 2019, 08:59 AM
What would be the corresponding turn signal switch to the 5-pin/6-wire wiper switch if i'm replacing both?
| Literati914 |
Jun 13 2019, 11:42 AM
What would be the corresponding turn signal switch to the 5-pin/6-wire wiper switch if i'm replacing both? (IMG:style_emoticons/default/idea.gif) I've been wondering the same.. need to study pics in one of the old threads. |
| Literati914 |
Jun 13 2019, 02:50 PM
What would be the corresponding turn signal switch to the 5-pin/6-wire wiper switch if i'm replacing both? From the first post in the following thread, I'm counting 9 wire connectors on the turn switch side .... http://www.914world.com/bbs2/index.php?sho...p;#entry1620396 It's possible that it would be this switch (I have a request in for a count from Cip): https://www2.cip1.com/ProductDetails.asp?Pr...2D953%2D513%2DF . |
| FlacaProductions |
Jun 13 2019, 02:56 PM
check this thread:
http://www.914world.com/bbs2/index.php?showtopic=338231 |
Lo-Fi Version | Time is now: 8th July 2026 - 01:05 AM |
