> Suspension advice needed, Front suspension is squeaking
Rjmathison
post Jun 22 2019, 01:15 AM
I have a 76 2.0 (owned for 27 years) and it still has all the original stock suspension components/sway bars. The front has been squeaking for years and I’m finally ready to address the issue(s).
Without breaking the bank, what should I order/install. The car has 55k original miles and is only driven during the summer on the streets. Any advice/input greatly appreciated!!
Mikey914
post Jun 22 2019, 01:18 AM
The rubber man
A arm bushings are probably the primary issue Not super easy, but Ian did a really good video
https://900designs-container.zoeysite.com/c...-install-tool-1
https://www.youtube.com/embed/5AysZlHr2lM
Also get more that the 4 bushings in case you mess one up. We will take back what you don't use no problem.
Rjmathison
post Jun 22 2019, 02:28 AM
QUOTE(Mikey914 @ Jun 22 2019, 02:18 AM) *
Thanks Mike !! I was planning on placing an order with you ! What’s your opinion on poly bushings vs the rubber ones ?
Cairo94507
post Jun 22 2019, 06:26 AM
Michael
I went with rubber in my car since I am not going to track it or auto-X it. In my experience the poly bushings tighten up the suspension for better handling, but at the cost of squeaking at times. I wanted to keep my car comfortable and quiet for the street and long drives. Rubber was my choice. Good luck. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Jun 22 2019, 06:48 AM
that's what I do!
(IMG:style_emoticons/default/agree.gif) If it's the squeak you want gone use the rubber.
All other options are mo' money.
thelogo
post Jun 22 2019, 06:59 AM
Group: Retired Members
QUOTE(Rjmathison @ Jun 22 2019, 12:15 AM) *
Once you start pulling apart 27 year old suspension
The bank may get broken .
If its just the arm bushings then great
But id prepare myself for something more expensive
(While your there , you may find other things )
Brake lines .... Ball joints ....struts ....
It never ends (IMG:style_emoticons/default/sawzall-smiley.gif)
914werke
post Jun 22 2019, 08:28 AM
(IMG:style_emoticons/default/agree.gif), if you are going to tear the front end down to rebuild the A arms it only make sense to rebuild the wear items that exist.
Ball joints & Tie rod ends (Turbo) are 1st on that list. Strut (inserts) are relatively easy can be done anytime and so I wouldn include them in this mix.
I see you are (semi) local so if you need some help or advice drop a line (IMG:style_emoticons/default/bye1.gif)
iankarr
post Jun 22 2019, 09:55 AM
(IMG:style_emoticons/default/agree.gif) 1000% Do it all together, then you'll also only need one alignment done. Definitely go for the turbo tie rods. Huge difference!
PS Thanks, Mark for the thumbs up on the video (IMG:style_emoticons/default/wink.gif)
Rjmathison
post Jun 22 2019, 10:30 AM
Thanks for the quick response gents ! Time to place an order and get dirty!!!!
dr914@autoatlanta.com
post Jun 22 2019, 10:58 AM
lube all of the suspension bushings with ruglyde rubber lubricant, should have been part of a 914 major service. Will squeak no more
Rjmathison
post Jun 22 2019, 12:50 PM
Thanks!!
Mikey914
post Jun 24 2019, 10:17 AM
The rubber man
QUOTE(Rjmathison @ Jun 22 2019, 01:28 AM) *
Poly graphite will work, but is actually not as good as the rubber.
lierofox
post Jun 24 2019, 12:06 PM
QUOTE(Mikey914 @ Jun 22 2019, 12:18 AM) *
Having done the job without using an install tool (Heat and soap. Lots, and lots, and LOTS of soap, I don't think I've ever seen the workbench so clean) my suggestion is: use the damn install tool.
Rjmathison
post Jun 24 2019, 12:18 PM
Great advice ! Thanks
- Lo-Fi Version Time is now: 26th December 2024 - 01:58 PM
