> FI Fuel Pump Pressure Reduction
rickso71
post Jun 30 2005, 04:49 AM
My 1.7L has been converted to carb. and not sure if I can just add a pressure reducer after the fuel pump or need a new low pressure pump.
SLITS
post Jun 30 2005, 06:49 AM
"This Utah shit is HARSH!"
The stock pump has a provision for "return to the tank". If you use a pressure regulator with it, get the one that also has a "return to the tank". Mallory makes one as I remember.
Otherwise, just buy a FACET pump and use a pressure regulator inline with no return to the tank.
ClayPerrine
post Jun 30 2005, 07:01 AM
Using the FI pump on carbs is a very good way to end up with a barbecued 914.
Buy a facet pump and put it on the car, or put the FI back and use the current pump.
- Lo-Fi Version Time is now: 26th December 2024 - 08:49 AM
