| Dominic |
Oct 7 2019, 09:44 PM
Dominic ![]() ![]() ![]() Group: Members Posts: 997 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
12/07/2019 UPDATE: SOLD!
11/26/2019 UPDATE: Sale Pending! 10/13/2019 UPDATE: Added more details / info and pictures to the last few posts. For Sale: I have decided to sell my 914-6, I have owned the car almost 5 years and have put less than 1000 miles on it in that time. I have come to the realization that I have too many projects / cars and not enough time. This is an original 6 that was restored several years back with Steel GT flares Paint: Signal Orange (Original Color) Engine: 1970 2.2S MFI engine rebuilt by Denny Aker's in Seattle Exhaust: Stock 914-6 heat exchangers with modified 911 muffler for 2 in / 2 out. Trans: Side Shift transaxle, stock -4 gear ratios, GT Torque Biasing Diff, J-west side shift linkage update Brakes: Front: 911S Alloy Calipers, Rears: 914-6 GT mod with drilled / vented rotors on all four corners Wheels: Fuchs 15x7" Fronts, 15x8" Rears (comes with 15x8" spare) Interior: Momo Prototipo wheel, GTS classic seats with houndstooth inserts, Nakamichi CD player with removable face and aftermarket speaker pods. Body / Exterior: Steel fender flares, steel rocker panels modified for flares, steel front valance modified for flares, GT engine lid built by Sergio Meza, Hella Euro lenses front and rear. Re-chromed front and rear original bumpers with license plate holed welded up on front bumper (high quality chrome work, you have to see these to appreciate how nice they are), new / perfect rubber bumper tops. Original side view mirror (drivers side only) Battery: Odyssey PC680 dry cell battery, rennline battery holder, hella battery cut-off switch, relocated to front trunk (see pics). Original Numbers matching 2.0L longblock included COA included with car along with large folder of records. Asking: $79,000 *Update: 11/12/2019 Lowered price to $75,000. Serious buyers will have to PM me with an actual phone number, internet scammers can F#ck-off (IMG:style_emoticons/default/mad.gif) I will add more pics and details in the coming days. As promised here is a list of items I have replaced since I have owned car. Work Performed Summer 2015: Installed new speedometer cable Installed new J-West side shifter linkage Install late style parking brake handle Installed 944 inertia reel seat belts Installed new Hella Euro front turn signal lenses Replaced front sway bar drop links with adjustable units Replaced front suspension bushings Replace oil pressure sender with new VDO 0-80 psi sender to match gauge Replace fuel tank sending unit with new VDO part Rebuilt pedal cluster with new bronze bushings, new clutch shaft and spring. Replaced right targa bar window seal Replaced Fuel Filler Cap seal Replaced old “914-6” emblem with NOS gold 914-6 script Installed new 12v power adapter under dash (for GPS/phone charger) Repainted petals all four Fuchs wheels with aluminum paint (RSR look) Remove muffler, cleaned, re-welded tail pipe, painted with grey ceramic paint Replaced MFI fuel filter in engine compartment Installed New Rear adjustable Koni shocks with coil over kit (175 lbs springs) Work performed Summer of 2018: Removed engine / Trans / Oil tank / Fuel Tank Installed New front motor mount Installed New Engine Comp Rubber Seals Installed new stainless steel fuel lines through tunnel. Installed new oil supply line from oil tank to engine. Adjusted valves, replaced valve cover gaskets with new silicon units (no leaks) Replaced alternator / alternator belt. Media blasted 11 blade fan and clear coated fan Installed new 123 Ignition programmable blue tooth Distributor Replaced rear brake hosed with new DOT Stainless steel lines. Cleaned and Tested all MFI injectors, replaced one bad injector Installed new IMI Hi-Torque Starter Recent Work Performed: Replaced alloy lug nuts - Oct 2019 Installed new Odyssey PC680 Battery – Oct 2019 Installed New first / Reverse Slider and 1st gear syncro – Oct 2019 Attached thumbnail(s) |
| raynekat |
Oct 8 2019, 12:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Looks like a great ride there Dominic.
GLWTS You should add a few more pics of like the interior, engine bay, trunks, etc. |
| Bruce Hinds |
Oct 8 2019, 05:43 AM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
WOW - If I could afford a 6 that would be the one!
If it doesn't stay in our "family" I'd love to see what it goes for on BAT. The prices are staggering. |
| Cairo94507 |
Oct 8 2019, 07:47 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,736 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Great looking Six- GLWTS. (IMG:style_emoticons/default/beerchug.gif)
| pete000 |
Oct 8 2019, 10:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
DON'T SELL IT !!
| BuddyV |
Oct 8 2019, 10:44 AM
Robert ![]() ![]() ![]() Group: Members Posts: 571 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California
| Dominic |
Oct 8 2019, 10:32 PM
More pics of Interior...
| EdwardBlume |
Oct 9 2019, 07:07 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
"Original Numbers matching 2.0L long block included" Great car. Great price. This car is a flippers paradise. This car is perfect in every way.... GLWTS |
| Mike Fitton |
Oct 9 2019, 08:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 13-May 11 From: Mount Prospect, IL Member No.: 13,069 Region Association: Upper MidWest
Looks like the Tach and combo gauge are non-original, is the speedometer original? Do you have original gauges? Does the dash have a cap on it, hard to tell from pictures.
| Rufus |
Oct 9 2019, 11:02 AM
Member ![]() ![]() Group: Members Posts: 314 Joined: 8-April 06 Member No.: 5,840 Region Association: None
This appears to be an awesome 914/6 ... I love it!
GLWTS BTW: Which transmission does it have? |
| a9146luvr |
Oct 9 2019, 11:30 AM
Member ![]() ![]() Group: Members Posts: 55 Joined: 2-January 04 Member No.: 1,495 Region Association: None |
If this is a "/car" that you are selling, i would really like to see the "project/" that you are keeping! Very nice! (IMG:style_emoticons/default/pray.gif)
| JOEPROPER |
Oct 9 2019, 11:54 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
If this is a "/car" that you are selling, i would really like to see the "project/" that you are keeping! Very nice! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/agree.gif) Love this car. I just printed out the 3 first pictures of the add in hopes of having mine turn out like this. Beautiful car GLWS. BTW is the sail panel painted? |
| flat4guy |
Oct 9 2019, 08:37 PM
Member ![]() ![]() Group: Members Posts: 483 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
Beautiful car - it's always a timing issue with me when the cool ones come up for sale. (IMG:style_emoticons/default/sad.gif)
| Dominic |
Oct 9 2019, 09:00 PM
Looks like the Tach and combo gauge are non-original, is the speedometer original? Do you have original gauges? Does the dash have a cap on it, hard to tell from pictures. Yes, someone once told me the Tach was a 911 Turbo tach with the boost converted to the oil pressure gauge. The dash is a very nice original dash pad (not a cap). I did not build the car so I don't know all of the details. Some More Pics... Attached thumbnail(s) |
| Dominic |
Oct 13 2019, 04:22 PM
More pics.. last one shows the rear trunk panel with the original chasis number stamping.
| sixnotfour |
Oct 29 2019, 11:45 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,309 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I bought it out of a Barn 1998?? 2011 BAT
https://www.flickr.com/photos/37210452@N06/...157628092486963 more intel. http://www.914world.com/bbs2/index.php?s=&...t&p=2758019 |
| RSWannabe |
Nov 8 2019, 01:48 PM
Newbie ![]() Group: Members Posts: 47 Joined: 20-August 06 From: Kirkland, WA Member No.: 6,692 |
I just had this ad brought to my attention. I'm the one who did the restoration on this car and sold it on BaT in 2011. Damn it's good to see it. Glad to see its been well maintained and continued to be improved.
Question for seller, When I sold it, it had a close ratio gear set in it. A, F, Ka, Q, X if I recall correctly. Was that swapped out for stock 4 gears or was the whole transmission swapped? |
| Dominic |
Nov 8 2019, 07:44 PM
I just had this ad brought to my attention. I'm the one who did the restoration on this car and sold it on BaT in 2011. Damn it's good to see it. Glad to see its been well maintained and continued to be improved. Question for seller, When I sold it, it had a close ratio gear set in it. A, F, Ka, Q, X if I recall correctly. Was that swapped out for stock 4 gears or was the whole transmission swapped? Just the gears were swapped out, it still has the GT Torque Biasing Differential. Thanks, Dominic |
| Dominic |
Nov 12 2019, 08:44 PM
| ben*james |
Nov 26 2019, 08:38 PM
LIFER ![]() ![]() ![]() Group: Members Posts: 525 Joined: 16-February 09 From: Portland Oregon Member No.: 10,062 Region Association: Pacific Northwest
Deposit made
Lo-Fi Version | Time is now: 11th August 2026 - 07:40 PM |
