343 Pages V « < 4 5 6 7 8 > »
> Rebuiding Inside-out
bkrantz
post Dec 29 2019, 10:05 PM
Post #101
Just the right position now for the next task: rehab the rusted floor.
bkrantz
post Dec 30 2019, 09:17 PM
Post #102
Another view of the car on the lift. I bought this rotisserie from Northern Tool. The design has two key features. Hydraulic rams at either end allow easy lifting and dropping by about 18 inches. This made it easy to attach the brackets with the car on jack stands, and then elevate it enough to clear the side while rotating to sideways. The second feature allows for tuning the position of the car relative to the pivots, thus getting the center of gravity close to the rotation axis.
Kansas 914
post Dec 31 2019, 08:02 AM
Post #103
It appears you achieved your goal while your son was in town. At this point the work becomes fun!
Did you uncover any surprises when you removed the suspension?
sixnotfour
post Dec 31 2019, 09:02 AM
Post #104
wow your goin for it...your garage is @Ferg worthy... (IMG:style_emoticons/default/beerchug.gif)
Kansas 914
post Dec 31 2019, 09:14 AM
Post #105
QUOTE(sixnotfour @ Dec 31 2019, 08:02 AM) *
Jeff - he needs a few more bikes! (IMG:style_emoticons/default/wink.gif)
bkrantz
post Dec 31 2019, 09:23 PM
Post #106
QUOTE(Kansas 914 @ Dec 31 2019, 07:02 AM) *
None obvious. We did drop the front as a complete assembly, and I still have to take it apart.
raynekat
post Jan 1 2020, 05:45 PM
Post #107
What? No updates on the 1st? (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/welder.gif)
Haha
Happy New Years Bob.
Your progress is looking great from way over here.
Superhawk996
post Jan 1 2020, 06:30 PM
Post #108
Sweet Rotisserie. I've always like the type like this with the hydraulic ram.
I measured my garage and determined that I'll have to remove the garage door opener and the upper guide tracks if I hope to use a rotisserie. (IMG:style_emoticons/default/sad.gif)
Looking like you've got this beat and are will on your way to easy street to work on the undersides.
bkrantz
post Jan 1 2020, 09:44 PM
Post #109
QUOTE(raynekat @ Jan 1 2020, 04:45 PM) *
Haha
Thanks, Doug--back at you guys, too.
Shirlee wanted to get outside and enjoy another snowy day, so we hiked the ridge behind our house--about 1000 ft up.
bkrantz
post Jan 1 2020, 09:45 PM
Post #110
And after that I got about an hour of garage time. Enough to separate the struts and steering rack from the front suspension, and pull the torsion bars.
bkrantz
post Jan 1 2020, 09:47 PM
Post #111
Torsion bars look like blue strip coding.
Kansas 914
post Jan 2 2020, 07:02 AM
Post #112
QUOTE(bkrantz @ Jan 1 2020, 08:47 PM) *
I'm sure you know this but don't mix up right and left torsion bars when re-installing. There should be a R & L stamped on the end.
Keep up the good work!
bkrantz
post Jan 2 2020, 08:59 PM
Post #113
QUOTE(Kansas 914 @ Jan 2 2020, 06:02 AM) *
Thanks for the reminder. I did see the L and R stamps.
bkrantz
post Jan 2 2020, 09:02 PM
Post #114
And on the the floor, starting with some rough cuts between all the welded seams. Next step is drilling out LOTS of spot welds.
bkrantz
post Jan 2 2020, 09:04 PM
Post #115
Inside the center tunnel is the obligatory mouse nest.
raynekat
post Jan 2 2020, 09:33 PM
Post #116
QUOTE(bkrantz @ Jan 2 2020, 07:04 PM) *
Now that is pretty glorious....and Shirlee, I don't jest. (IMG:style_emoticons/default/wink.gif)
bkrantz
post Jan 3 2020, 09:07 PM
Post #117
QUOTE(raynekat @ Jan 2 2020, 08:33 PM) *
And that's just the part I could not vacuum out through the holes in the top of the tunnel.
bkrantz
post Jan 3 2020, 09:09 PM
Post #118
Now for the surgical removal of the rest of the rear floor, starting on the left side. BTW access on the rotisserie, and also raising the lowering the car height, is glorious.
First drill out the welds and remove the jacking donut.
bkrantz
post Jan 3 2020, 09:11 PM
Post #119
Then drill out the welds and remove the triangular gusset.
bkrantz
post Jan 3 2020, 09:12 PM
Post #120
Then a happy hour or so of drilling out spot welds along the sill, tunnel, and firewalls.
- Lo-Fi Version Time is now: 9th April 2025 - 11:00 PM
