343 Pages V « < 54 55 56 57 58 > »
> Rebuiding Inside-out
bkrantz
post Aug 14 2020, 08:35 PM
Post #1101
Starting with the yellow wire, I carefully removed the crimp connectors.
bkrantz
post Aug 14 2020, 08:36 PM
Post #1102
Then weave the wire cores together.
bkrantz
post Aug 14 2020, 08:37 PM
Post #1103
Then solder.
bkrantz
post Aug 14 2020, 08:39 PM
Post #1104
I did the same for the red lead (and I managed to remember the heat shrink tubing for both).
bkrantz
post Aug 14 2020, 08:40 PM
Post #1105
Slide the tubing into place. This is marine grade with internal adhesive.
bkrantz
post Aug 14 2020, 08:41 PM
Post #1106
Then hit it with the heat gun.
bkrantz
post Aug 14 2020, 08:42 PM
Post #1107
I did the same repair on two leads to the light switch.
bkrantz
post Aug 14 2020, 08:44 PM
Post #1108
Today was another milestone. I went to the powder coat shop to fetch the first batch of refinished components. I used Evolution Powdercoating in Durango--highly recommended.
bkrantz
post Aug 14 2020, 08:46 PM
Post #1109
Checking out all the parts. I remember everything except the heat exchanger ductwork, which got high temp powder coat.
bkrantz
post Aug 14 2020, 08:47 PM
Post #1110
Here's the engine sheet metal, air filter housing, and intake plenum.
bkrantz
post Aug 14 2020, 08:49 PM
Post #1111
Of course, powder coat, like paint, reveals any flaws in the metal. The section where I welded cracks is not perfect, but will work.
bkrantz
post Aug 14 2020, 08:50 PM
Post #1112
Here's the front suspension, with a slightly lumpy steering cover.
bkrantz
post Aug 14 2020, 08:53 PM
Post #1113
And the rear suspension. The biggest miscommunication led to getting the inside of the rear wheel bearing cavity powder coated. I will need to remove this before installing the bearings. The shop did a great job of protecting other areas and all threaded holes.
bkrantz
post Aug 15 2020, 08:13 PM
Post #1114
I got my supply of colored wire (4RCustomsWire) and metric connectors (Bel Metric).
bkrantz
post Aug 15 2020, 08:14 PM
Post #1115
Also a first time to use my fancy crimp tool, with correct jaws fitted.
bkrantz
post Aug 15 2020, 08:15 PM
Post #1116
Here's a test crimp, with a typical spade connector. Looks very correct.
bkrantz
post Aug 15 2020, 08:18 PM
Post #1117
And here's a typical repair: replacing about 6 inches of mangled original wire with the new piece soldered onto the remaining lead, covered with heat shrink tubing, a new connector, and heat shrink on that, too.
bkrantz
post Aug 15 2020, 08:19 PM
Post #1118
For another repair, I replaced a complete section of wire, from one connector to the next. The crimp tool handles double wire without a problem. (The new wire color match is not perfect, tan vs. brown).
bkrantz
post Aug 15 2020, 08:20 PM
Post #1119
New ring terminals for the battery tie-in, crimped and soldered.
bkrantz
post Aug 15 2020, 08:21 PM
Post #1120
Another repair for a mangled lead--I even matched the green wire with white stripe (sort of).
- Lo-Fi Version Time is now: 21st April 2025 - 08:29 PM
