bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,343 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Here are the extensions for the fuel pump wires, attached to the leads that I re-routed through the snorkel. The new wires will eventually run all the way to the relocated pump up front.
Attached thumbnail(s) ![]() |
djway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California ![]() |
If you don't already to this for a single wire terminal I start with the large jaw and crimp then I move to the middle jaw and get a much better result.
Keep on Crimpin. |
bkrantz |
More wire repair today. Here's a replacement for the power lead to the cig lighter.
bkrantz |
And after a bit of black marker, the match is better.
bkrantz |
This is a real nice example of PO handiwork, a wire spliced into a lead to the left door switch. Presumably, this was for the aftermarket alarm.
bkrantz |
Step 1: Replace the mangled section.
bkrantz |
Step 2: Insulate the splice, and crimp both leads into a new mini-connector.
bkrantz |
Step 3: Insulate the connector, and bundle all the leads in prep for wrapping the harness with new tape.
bkrantz |
Here's a real special example. Twinned leads from one of the head light fuses, all melted. A PO short?
bkrantz |
Replaced, with some black marker stripes added.
bkrantz |
After measuring a friend's 914 (thanks, Mike!) I decided to complete the rear portion of the harness (everything in the trunk).
Here's the wiring laid out to match dimensions marked on the table. Attached thumbnail(s) ![]() |
bkrantz |
The center needs the most work, where I have to rebuild the leads to the license plate lights.
bkrantz |
Here are the new wires, with connectors and insulation.
bkrantz |
And then wrapped with harness tape (from 914 Rubber).
bkrantz |
Wrapping the harness take a Zen mind state, trying to keep the spiral constant. Practice from years of wrapping road bike handlebars helps. I am glad to have one part of the harness done!
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,298 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
That harness looks really nice. (IMG:style_emoticons/default/beerchug.gif)
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,965 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
bkrantz |
Thanks, Cairo.
Those butt connectors should work, but for the heavy gauge leads (for higher amp current), soldering might be better. Any EE types can tell us the truth. |
bkrantz |
More wire work today. I got some additional materials: super adhesive stretchy rubber tape and paint-on rubber coating, both by 3M. I am using these to patch wires with small nicks or cuts in the insulation.
bkrantz |
This makes the repair a little bulky, but I think better than cutting and splicing.
Lo-Fi Version | Time is now: 21st April 2025 - 10:14 PM |
