343 Pages V « < 57 58 59 60 61 > »
> Rebuiding Inside-out
ndfrigi
post Aug 20 2020, 09:27 PM
Post #1161
QUOTE(bkrantz @ Aug 20 2020, 07:14 PM) *
I continued with all the wiring under the dash. That finishes everything in the interior and rear.
nice! good job @bktantz!
bkrantz
post Aug 21 2020, 08:35 PM
Post #1162
More forward progress today. Here are all the leads for under the cowl done, except for the wires that will go to the relocated fuel pump. I will finish these after I mount the pump.
bkrantz
post Aug 21 2020, 08:36 PM
Post #1163
I made some progress on the last section, that feeds all the front lights. Slow going due to lots of spots of PO red overspray.
autopro
post Aug 21 2020, 08:50 PM
Post #1164
You are doing some great work wow! How are you removing the paint from the wires? Does it remove the markings on the wires when you do it? My harness is in very bad shape similar to yours and I will have to go through this process like you are doing.
bkrantz
post Aug 22 2020, 08:41 PM
Post #1165
QUOTE(autopro @ Aug 21 2020, 08:50 PM) *
I have tried and use different things. The undercoating and greasy dirt come off easiest with GoofOff, but that does not work on paint. For light overspray, acetone works pretty well. For small spots of thicker paint (like between the original tape wrap), I scrape lightly with a new, sharp utility blade, and then use acetone. For really thick paint, I use a standard paint remover, but this does soften the sleeve material, so I use it carefully.
See the example below.
bkrantz
post Aug 22 2020, 08:44 PM
Post #1166
Onto the final section today, working towards the front lights. Here's some nasty PO red (and gold???) overspray.
bkrantz
post Aug 22 2020, 08:45 PM
Post #1167
After scraping and cleaning with acetone.
bkrantz
post Aug 22 2020, 08:46 PM
Post #1168
And the final bit has even more paint.
bkrantz
post Aug 22 2020, 08:47 PM
Post #1169
The last section all wrapped up.
bkrantz
post Aug 22 2020, 08:49 PM
Post #1170
That's it! The main harness all done, except for a few connectors that I will mount when I install the harness in the car.
bkrantz
post Aug 22 2020, 08:51 PM
Post #1171
While on a role, I attacked the ignition harness. This had a crimp connector in the middle of the power lead. In order to pull a new wire through the sleeve, I soldered it to the end of the old wire.
bkrantz
post Aug 22 2020, 08:52 PM
Post #1172
After squirting some soapy water in the first sleeve, I pulled the new wire through.
bkrantz
post Aug 22 2020, 08:53 PM
Post #1173
And then did the same with the second sleeve, to get the new wire to the multi-pin plug.
bkrantz
post Aug 22 2020, 08:54 PM
Post #1174
And then I moved the pin connector from the end of the old wire...
bkrantz
post Aug 22 2020, 08:55 PM
Post #1175
to the new wire.
bkrantz
post Aug 22 2020, 08:56 PM
Post #1176
Here's the pin back in the correct hole in the plug (I hope).
bkrantz
Post #1177
And the plug cap back in place.
bkrantz
post Aug 22 2020, 08:58 PM
Post #1178
And the ignition harness is ready to go (I will install the ring connector on the new wire when I have everything back on the engine).
djway
post Aug 22 2020, 11:53 PM
Post #1179
I don't remember, have you used a continuity tester on each line to confirm first you have a good circuit and that you have the correct wire to each point?
Easiest to check while out.
Excellent work on the harness.
bkrantz
post Aug 23 2020, 07:36 PM
Post #1180
QUOTE(djway @ Aug 22 2020, 11:53 PM) *
To be honest, I did some testing when I first inspected the harness, but found problems only where I could also see visible damage. After that I got lazy and did not test every wire or connector.
- Lo-Fi Version Time is now: 21st April 2025 - 11:23 PM
