343 Pages V « < 5 6 7 8 9 > »
> Rebuiding Inside-out
bkrantz
post Jan 3 2020, 09:13 PM
Post #121
Then some sections can come free, exposing the interior firewall space--and a bit of surface rust (but not looking bad).
bkrantz
post Jan 4 2020, 09:17 PM
Post #122
Only had about an hour in the garage today, so just finished up the rest of the left side. I will get the remaining interior remnants once I spin the car to horizontal.
bkrantz
post Jan 4 2020, 09:19 PM
Post #123
I discovered the trailing edge of the tunnel has welding, in addition to the spot welds.
bkrantz
post Jan 4 2020, 09:21 PM
Post #124
Getting ready to work on the right side, which was down near floor level. With the lift feature of the rotisserie, I was able to raise the car about 18 inches, and make the working height much better. Nice feature.
sixnotfour
post Jan 5 2020, 06:26 PM
Post #125
bkrantz
post Jan 5 2020, 09:08 PM
Post #126
Got the other side done today. Now I need to grind off the spot weld remnants and clean up rusty metal--and look for any spots that need replacement.
bkrantz
post Jan 5 2020, 09:09 PM
Post #127
Here's the rear floor, in pieces after removal.
bkrantz
post Jan 5 2020, 09:11 PM
Post #128
Interior cross brace is also fully gone. Ground off a few surface welds (not spot welds) at the center tunnel.
bkrantz
post Jan 5 2020, 09:14 PM
Post #129
Before fitting the new floor I have a few things to fix, including a dent in the bottom of the right long. Probably a dumb attempt to jack the car up from the middle. The photo makes it look like only the flange is pushed in, but the flat surfaces are also bent.
altitude411
post Jan 5 2020, 09:22 PM
Post #130
I drove my 6 into a tree
Fantastic work and photos. Thanks for posting. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Kansas 914
post Jan 6 2020, 06:26 AM
Post #131
QUOTE(altitude411 @ Jan 5 2020, 08:22 PM) *
Agreed!
You are really doing a terrific job documenting your work to the benefit of anyone that will face this task in the future.
bkrantz
post Jan 6 2020, 09:28 PM
Post #132
QUOTE(Kansas 914 @ Jan 6 2020, 05:26 AM) *
Agreed!
Thanks, Mike. Documentation makes it more fun for me.
bkrantz
post Jan 6 2020, 09:32 PM
Post #133
Now for the front corners. I had already explored the left side, so just some clean up (drill out the seam spot welds and clean up the sill surface). Sill looks solid.
bkrantz
post Jan 6 2020, 09:34 PM
Post #134
Right corner floor looks about the same, just a slightly bigger area cut out. But the inner sill has a rust hole!
bkrantz
post Jan 6 2020, 09:36 PM
Post #135
Fortunately, the rust-through on the sill is small, and the rust was eroding from outside in. This should be easy to patch before jabbing a new floor corner.
bkrantz
post Jan 6 2020, 09:39 PM
Post #136
Another sill problem: the inside of the left sill has the classic web of cracks, near the folded recess for grabbing the parking brake lever.
bkrantz
post Jan 6 2020, 09:41 PM
Post #137
For better access I drilled out the rest of the spot welds to detach the left edge of the remaining floor. With the floor propped out, I ground a recess along each crack for better weld penetration.
bkrantz
post Jan 6 2020, 09:43 PM
Post #138
Just for fun before quitting today, I mounted the replacement floor section. Fits nicely, but will need trimming on all sides.
bkrantz
post Jan 6 2020, 09:44 PM
Post #139
And looks good on the inside.
bkrantz
post Jan 7 2020, 09:17 PM
Post #140
Just some trivial work today, straightening one of the rear floor triangle braces.
- Lo-Fi Version Time is now: 9th April 2025 - 10:58 PM
