343 Pages V « < 66 67 68 69 70 > »
> Rebuiding Inside-out
bkrantz
post Sep 15 2020, 08:01 PM
Post #1341
The end of the block sits just below the housing face. I measured 0.1 mm.
bkrantz
post Sep 15 2020, 08:02 PM
Post #1342
Next, I measured the recess in the cover plate, 1.7 mm.
bkrantz
post Sep 15 2020, 08:04 PM
Post #1343
Then I measured the thickness of the original shim, and the gasket.
bkrantz
post Sep 15 2020, 08:07 PM
Post #1344
Here's the math. The total gap, including the gasket, is 2.1 mm. The designed gap is 0.2 mm. Can you spot my math error? The desired shim should be 1.9 mm! But the original shim is 1.85 mm, so all is well.
bkrantz
post Sep 15 2020, 08:08 PM
Post #1345
Here's the pressure spring, and the cover plate with shim ready to install.
bkrantz
Post #1346
Finally, here is the rack all done.
autopro
post Sep 16 2020, 11:59 AM
Post #1347
This is awesome, I will be doing this to my rack soon. Thanks for the picture of the seal as finding a replacement was one of my concerns. (IMG:style_emoticons/default/smile.gif)
bkrantz
post Sep 16 2020, 07:40 PM
Post #1348
Steering rack, part 2.
I started with the eye-bolt build kit.
bkrantz
post Sep 16 2020, 07:42 PM
Post #1349
No instructions, so I made up my own.
Here's the bushing and eye-bolt on the press, with plenty of liquid soap. Centering is important.
bkrantz
post Sep 16 2020, 07:44 PM
Post #1350
After the first attempt to press in the bushing. Watch out for pinching the rubber edge between the piston and the eye-bolt. Ask me how I know.
bkrantz
post Sep 16 2020, 07:46 PM
Post #1351
Another squeeze, just to the limit of pinching.
bkrantz
post Sep 16 2020, 07:48 PM
Post #1352
With the pressure released, the bushing rebounded a bit.
bkrantz
post Sep 16 2020, 07:49 PM
Post #1353
I then pressed into a 27mm socket, matching the outer rim of the eye bolt.
bkrantz
post Sep 16 2020, 07:50 PM
Post #1354
That was enough to get just a bit of the bushing edge out the other side of the eye bolt.
bkrantz
post Sep 16 2020, 07:51 PM
Post #1355
I then used my blunt ex-screw driver pry tool to ease the edge out all around.
bkrantz
Post #1356
Done.
bkrantz
post Sep 16 2020, 07:52 PM
Post #1357
Then I pressed in the metal center bushing. Again, lots of soap.
bkrantz
post Sep 16 2020, 07:53 PM
Post #1358
And then a smaller socket to press against the rubber bushing.
bkrantz
post Sep 16 2020, 07:54 PM
Post #1359
Centered.
bkrantz
post Sep 16 2020, 07:57 PM
Post #1360
Ready for the final assembly. The specs come from the factory shop manual, and specify the lateral dimensions (278 mm left and right from center) and the angle of the eye bolts (9 degrees down to the rear).
- Lo-Fi Version Time is now: 22nd April 2025 - 01:54 PM
