343 Pages V « < 67 68 69 70 71 > »
> Rebuiding Inside-out
bkrantz
post Sep 16 2020, 07:58 PM
Post #1361
I then put on the bellows (small end to the inside).
bkrantz
post Sep 16 2020, 07:59 PM
Post #1362
And the eye bolts with the stop plates.
bkrantz
post Sep 16 2020, 08:00 PM
Post #1363
To get the rack to sit properly horizontal, I made a pair of stands that screw into the rack mounting holes.
bkrantz
post Sep 16 2020, 08:01 PM
Post #1364
With a little adjustment, the rack now sits horizontal.
bkrantz
post Sep 16 2020, 08:03 PM
Post #1365
To measure the angles of the eye bolts, I grabbed some long bolts, and some tape to shim these for a snug fit.
bkrantz
post Sep 16 2020, 08:04 PM
Post #1366
Here's a top view, with the bolts propped up on some 2x4 blocks.
bkrantz
post Sep 16 2020, 08:05 PM
Post #1367
Lucky 2x4 thickness! The angle is right on 9 degrees.
bkrantz
post Sep 16 2020, 08:09 PM
Post #1368
Next is to measure the lateral dimension, with the rack itself centered. The spec is 278 mm. Note that the adjustment is a bit crude, since the eyebolt has to screw in or out a complete revolution to maintain the proper angles, both down to the rear and turned out to the front (as seen from above).
bkrantz
post Sep 16 2020, 08:11 PM
Post #1369
I set both sides. Interesting that the left side was screwed in fully, while the right side was out one full turn.
bkrantz
post Sep 16 2020, 08:12 PM
Post #1370
I snugged up the lock rings, but will check dimensions one more time tomorrow before final tightening.
bkrantz
post Sep 17 2020, 06:45 PM
Post #1371
Final bits today for the steering rack. I did double check dimensions and angles, and then tightened the lock rings. Got this tool for the job.
bkrantz
post Sep 17 2020, 06:47 PM
Post #1372
Here's all the parts gathered for installing the lower steering shaft. That includes a new rubber coupler and lock plates.
bkrantz
post Sep 17 2020, 06:48 PM
Post #1373
The coupler first mounts to the lower shaft.
bkrantz
post Sep 17 2020, 06:49 PM
Post #1374
After torquing to proper spec, the ends of the lock plate fix the bolt heads.
bkrantz
post Sep 17 2020, 06:51 PM
Post #1375
And then the coupler bolts onto the rack input yoke.
bkrantz
Post #1376
Lock these bolts in place, too.
bkrantz
post Sep 17 2020, 06:53 PM
Post #1377
Then comes the plastic cover and the lower shaft bearing. Ready for installation.
bkrantz
post Sep 18 2020, 07:40 PM
Post #1378
Just some minor progress today. I took another batch of parts out of the Evapo-rust bucket, including the frame for the parking brake switch. Here it is reassembled.
bkrantz
post Sep 18 2020, 07:42 PM
Post #1379
Also from the bucket, the transaxle mount pieces.
bkrantz
post Sep 18 2020, 07:44 PM
Post #1380
And starting on the parking brake lever. A bit ugly.
- Lo-Fi Version Time is now: 22nd April 2025 - 01:54 PM
