343 Pages V « < 68 69 70 71 72 > »
> Rebuiding Inside-out
bkrantz
post Sep 19 2020, 07:18 PM
Post #1381
A bit of garage cooking, to warm up the plastic grip.
bkrantz
post Sep 19 2020, 07:19 PM
Post #1382
Grip removed, and a bit more cleanup.
bkrantz
post Sep 19 2020, 07:24 PM
Post #1383
Primed and painted.
raynekat
post Sep 19 2020, 07:29 PM
Post #1384
Much better looking there Bob. Nice
bkrantz
post Sep 19 2020, 07:31 PM
Post #1385
Now for the big job of the day: installing the rubber bushings on the front A-arms.
I decided to try some different methods. First, I did not heat the bushings or other parts. Second, I put my new taller press to use. I had the same Dake press in a bench top model but could not fit the A-arms (or some other things). My son has been wishing for a press, so his birthday will come early.
bkrantz
post Sep 19 2020, 07:34 PM
Post #1386
Here's my process.
1. Press the bushing into the rear housing. Lots of liquid soap.
bkrantz
post Sep 19 2020, 07:36 PM
Post #1387
2. Bushing pressed in.
bkrantz
post Sep 19 2020, 07:37 PM
Post #1388
Here's the 914 Rubber inner guide, to ease the bushing onto the A-arm. The tape makes for a snug fit to center the guide.
bkrantz
post Sep 19 2020, 07:38 PM
Post #1389
The guide in place.
bkrantz
post Sep 19 2020, 07:40 PM
Post #1390
3. Starting to press the bushing on, over the guide. The stack include the other 915 Rubber guide, with the recessed end inserted into the housing. Lots more soap.
bkrantz
post Sep 19 2020, 07:43 PM
Post #1391
Pressed all the way on. With the pressure released, the bushing rebounded a bit.
bkrantz
post Sep 19 2020, 07:46 PM
Post #1392
So I reversed the guide and pressed again against the housing. I also left the pressure on for a few minutes to allow the rubber bushing to creep into place.
bkrantz
post Sep 19 2020, 07:48 PM
Post #1393
4. Once installed, the bushing and housing must be adjusted to the proper angle to ease A-arm installation.
First, set the arm horizontal (and right side up).
bkrantz
post Sep 19 2020, 07:50 PM
Post #1394
Then, check the angle of the housing. It should be 14 degrees from vertical, rotated "up". First check shows only 10.
bkrantz
post Sep 19 2020, 07:51 PM
Post #1395
A bit of twisting.
bkrantz
Post #1396
Now 14 degrees.
bkrantz
post Sep 19 2020, 07:54 PM
Post #1397
5. Install the rubber bushings into the front A-arm body mounts. Note that the mounts have a top and bottom, with the raised bosses on the top.
bkrantz
post Sep 19 2020, 07:56 PM
Post #1398
Like the rears, lots of soap, and press the rubber bushings into the mounts.
bkrantz
Post #1399
Ready for the A-arms.
bkrantz
post Sep 19 2020, 07:59 PM
Post #1400
6. Pressed into place.
- Lo-Fi Version Time is now: 22nd April 2025 - 05:08 PM
