Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I'll call Sunday afternoon when we're driving down.
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,343 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
bkrantz |
Back in town and ready to make some progress.
First, an inventory of stuff that arrived recently from PMB and other sources. Attached thumbnail(s) ![]() |
bkrantz |
I had the seat belt webbing replaced by Safety Restore. More yellow!
bkrantz |
I vacuumed and blew out all the tubes and ducts.
bkrantz |
I found a fair amount of sand in the heat tubes.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
I found a fair amount of sand in the heat tubes. I reversed my shop vac thru my heater tubes and a shop towel came flying out of one side along with a bunch of nasty dirt/stuff. Definitely a good idea as you don't want all that stuff heading back towards the cabin. (IMG:style_emoticons/default/wink.gif) |
bkrantz |
I found a fair amount of sand in the heat tubes. I reversed my shop vac thru my heater tubes and a shop towel came flying out of one side along with a bunch of nasty dirt/stuff. Definitely a good idea as you don't want all that stuff heading back towards the cabin. (IMG:style_emoticons/default/wink.gif) That sounds exciting. All I got was sand. |
bkrantz |
More post-paint body prep. While I am still very satisfied with the quality work the shop did, I found a few problem areas. First, after the dustless blasting, they missed a few small places where the abrasive was caked into seams or other sheltered places. And the blasting missed a few areas, and left a layer of the undercoat that the PO applied everywhere.
Worst was the upper right rear part of the engine compartment. A few spots of new paint had flaked off, and some gentle probing took off more. After that I got aggressive with a wire brush and sand paper. Attached thumbnail(s) ![]() |
bkrantz |
Another trouble spot was the right suspension ear, with the same problem where blasting left undercoat.
bkrantz |
After cleaning and primer.
bkrantz |
I then applied additional seam sealer in a few places the shop missed (or did not use enough).
Some extra on the front floor plugs. Attached thumbnail(s) ![]() |
bkrantz |
Inside the right front fender.
bkrantz |
Same fender along the top.
bkrantz |
And the rear edge.
bkrantz |
Next was the right rear fender, starting along the top.
bkrantz |
And the rear corner. I added a length of tubing to the cartridge tip to get sealant into the top recess.
bkrantz |
And extra seam sealant in the hell hole.
bkrantz |
After all that work, I had a fun visit with Kansas914 and Gint. Not sure how encouraged I should feel when they both revealed 914 projects underway for more than 10 years.
Lo-Fi Version | Time is now: 23rd April 2025 - 03:31 AM |
