342 Pages V « < 77 78 79 80 81 > »
> Rebuiding Inside-out
bkrantz
post Nov 10 2020, 08:34 PM
Post #1561
As a replacement, he ordered a steel replacement from URO.
bkrantz
post Nov 10 2020, 08:35 PM
Post #1562
All done, successfully running again.
bkrantz
post Nov 10 2020, 08:37 PM
Post #1563
While he was working, I started painting the spots I had scraped and primed, or applied seam sealer.
bkrantz
post Nov 10 2020, 08:38 PM
Post #1564
First coat in the hell hole and below.
djway
post Nov 10 2020, 08:51 PM
Post #1565
Beautiful.
UROpartsman
post Nov 11 2020, 11:34 AM
Post #1566
QUOTE(bkrantz @ Nov 9 2020, 06:59 PM) *
My son ordered an optional steel pan to replace the stock plastic piece. It should be tougher.
Well done Bkrantz!
• URO Parts has offered steel Oil Pan 06J 103 600AF for 2008-2014 GTI (cars without oil level sensor also require Oil Level Sender Cover 03G 103 707) for about a year, with great feedback.
• We offer aluminum pan 06K 103 600R-PRM for 2015-2016 GTI cars that originally came with the honeycomb plastic pan, which appears to be the factory pan on your son's car.
What year is your son's GTI? It looks like he may have bought the wrong pan, even if the flange bolt pattern is the same. The 2008-2014 steel pan is slightly deeper and will hang lower than the 2015-2016 honeycomb aluminum pan, and is more likely to catch speedbumps, etc. Sent you a PM.
bkrantz
post Nov 11 2020, 07:32 PM
Post #1567
I finished spraying color today (I think), and got coverage on all the spots, including the added seam sealer. I will add some clear coat and call it done.
bkrantz
Post #1568
Other side
bkrantz
post Nov 11 2020, 07:33 PM
Post #1569
Left side hell hole.
bkrantz
post Nov 12 2020, 07:24 PM
Post #1570
I touched up the last few spots, including in the frunk weatherstrip channel.
bkrantz
post Nov 13 2020, 07:25 PM
Post #1571
OK, except for a few very small spots, the paint is now complete. Time to start building.
Kansas 914
post Nov 13 2020, 09:03 PM
Post #1572
QUOTE(bkrantz @ Nov 13 2020, 06:25 PM) *
Great job!
Now the fun begins.
bkrantz
post Nov 14 2020, 07:34 PM
Post #1573
QUOTE(Kansas 914 @ Nov 13 2020, 08:03 PM) *
Great job!
Now the fun begins.
Indeed!
My initial plan:
1. Dynamat on floor and inside of firewall.
2. Fuel lines in tunnel.
3. Brake line in tunnel.
4. Cables in tunnel.
5. Wiring harness.
Comments?
bkrantz
post Nov 14 2020, 07:40 PM
Post #1574
Before adding parts to the body, I decided to add some rust prevention in the cavities, especially the longs. I have had a couple of cans of Eastwood Internal Frame Coating sitting around for months.
bkrantz
post Nov 14 2020, 07:41 PM
Post #1575
I used the access holes to get inside the longs.
bkrantz
post Nov 14 2020, 07:42 PM
Post #1576
The nozzle and hose are small enough diameter to sneak past obstructions.
bkrantz
post Nov 14 2020, 07:43 PM
Post #1577
Access to the upper part of the rear longs.
bkrantz
post Nov 14 2020, 07:46 PM
Post #1578
And also inside the tunnel. The nozzle sprays a 180 degree pattern.
In addition, I sprayed inside the lower firewall, the closed brace by the driver pedal area, the cross brace in the trunk, and the side braces under the fuel tank.
bkrantz
post Nov 14 2020, 07:47 PM
Post #1579
Prelims almost done.
Kansas 914
post Nov 14 2020, 08:02 PM
Post #1580
Great work!
- Lo-Fi Version Time is now: 27th November 2024 - 05:27 PM
