342 Pages V « < 82 83 84 85 86 > »
> Rebuiding Inside-out
bkrantz
post Dec 13 2020, 08:14 PM
Post #1661
Next, SS fuel lines, from Tangerine. These get fed in from the rear.
bkrantz
post Dec 13 2020, 08:18 PM
Post #1662
I had a moment of panic, when I could not find the double-hole rubber grommet for the front bulkhead. After looking in the "right" box and not finding it, I went through all the other boxes. Of course, it was in the right box after all. Good think, since this grommet is NLA.
bkrantz
post Dec 13 2020, 08:19 PM
Post #1663
Grommet in place.
bkrantz
post Dec 13 2020, 08:21 PM
Post #1664
And a single grommet in one rear hole. I used some teflon spray lube, and fed the fuel line in. Once started, it was actually easy to push it to the front.
bkrantz
post Dec 13 2020, 08:22 PM
Post #1665
Repeat for the second line.
bkrantz
post Dec 13 2020, 08:25 PM
Post #1666
Front end of the tunnel, with the lines fed through the double-hole grommet.
bkrantz
post Dec 13 2020, 08:26 PM
Post #1667
Future connections for the fuel tank and relocated pump.
bkrantz
post Dec 13 2020, 08:28 PM
Post #1668
One more detail for the fuel lines: fixing them in place using the tabs on the floor of the tunnel, with some rubber hose as protection.
bkrantz
post Dec 13 2020, 08:29 PM
Post #1669
Bonus detail: some more rubber hose collars to keep the lines from vibrating on the rear tunnel floor.
bkrantz
post Dec 13 2020, 08:30 PM
Post #1670
Out with the old list (I will get to painting under the side grills later, and clean the threads as I go).
bkrantz
post Dec 13 2020, 08:31 PM
Post #1671
In with the new list. Progress already!
bkrantz
post Dec 14 2020, 07:47 PM
Post #1672
Finishing up this detour. The fuse-relay panel is clean, and I wired the washer pump switch and relay. The new relay is the one lower left.
bkrantz
post Dec 14 2020, 07:49 PM
Post #1673
I then re-taped the harness, including new wires to the future pump (coil of white and brown). I will cut to fit and add necessary connectors once the pump is installed.
bkrantz
post Dec 14 2020, 07:52 PM
Post #1674
Now for the big job--installing the harness. Not really looking forward to this. (IMG:style_emoticons/default/dry.gif)
ndfrigi
post Dec 14 2020, 08:05 PM
Post #1675
QUOTE(bkrantz @ Dec 14 2020, 05:49 PM) *
wow! congratulations and nicely done on your wiring too!
Can you also share the wiring along the center tunnel all the way to the rear wiring?
I’m also going to fix my wiring for my 74. thank you!
ooops there you go complete wiring except hardly can look at it because of the floor dynamat color.
djway
post Dec 14 2020, 08:21 PM
Post #1676
bkrantz
post Dec 15 2020, 08:04 PM
Post #1677
QUOTE(ndfrigi @ Dec 14 2020, 07:05 PM) *
If you mean showing the rear part of the wiring harness and individual connections, look back on this thread for when I had the harness laid-out during and after when I cleaned and repaired it.
If you mean showing the installation in the car, stay tuned.
gereed75
post Dec 16 2020, 08:13 AM
Post #1678
In All likelihood you have seen it but RD has a pretty good video out there on installing the harness.
Really enjoy your threads. Nice work.
bkrantz
post Dec 16 2020, 08:03 PM
Post #1679
OK, here we go. Prep: good mood, cold beverage, calm music.
Everything on the cardboard is the rear "half" that goes under the cross brace and all the way back to the tail lights.
bkrantz
post Dec 16 2020, 08:07 PM
Post #1680
To start, I used (mostly) the strategy of feeding the biggest thing through the obstruction first, even if not on the far end of the harness. So here goes the relay board connector under the center tunnel brace.
- Lo-Fi Version Time is now: 27th November 2024 - 11:41 PM
