342 Pages V « < 83 84 85 86 87 > »
> Rebuiding Inside-out
bkrantz
post Dec 16 2020, 08:08 PM
Post #1681
Then the far end of the rear harness, with the right tail light connectors leading.
bkrantz
post Dec 16 2020, 08:09 PM
Post #1682
After pulling the tail light branch, I started the battery leads.
Note the red spots.
bkrantz
post Dec 16 2020, 08:11 PM
Post #1683
I pulled both branches through until the snorkel got to the tunnel.
bkrantz
post Dec 16 2020, 08:12 PM
Post #1684
Snorkel started.
bkrantz
post Dec 16 2020, 08:13 PM
Post #1685
And through.
bkrantz
post Dec 16 2020, 08:17 PM
Post #1686
All done! (with the first obstacle). I also fed the wires for the heat lever to that opening.
bkrantz
post Dec 16 2020, 08:18 PM
Post #1687
Now comes the real fun. All the rear harness now has go into the tunnel and out the hole in the lower firewall into the engine compartment.
bkrantz
post Dec 16 2020, 08:21 PM
Post #1688
I violated my "big things first" strategy by starting with the far end tail light lead.
bkrantz
post Dec 16 2020, 08:22 PM
Post #1689
This was pretty easy to sneak into the tunnel and then feed out into the engine compartment.
bkrantz
post Dec 16 2020, 08:23 PM
Post #1690
I continued to pull that branch, and got more side branches through.
bkrantz
post Dec 16 2020, 08:25 PM
Post #1691
Now the test for my current strategy: will the big plug have room to get through?
bkrantz
post Dec 16 2020, 08:26 PM
Post #1692
It took a bit of fiddling, but it worked.
bkrantz
Post #1693
Now for the battery leads.
bkrantz
post Dec 16 2020, 08:28 PM
Post #1694
Using long shop tweezers helps to get the lead ends through the hole.
bkrantz
Post #1695
And the rest of the leads.
bkrantz
post Dec 16 2020, 08:29 PM
Post #1696
Now for the snorkel. Into the tunnel!
bkrantz
post Dec 16 2020, 08:30 PM
Post #1697
All in.
bkrantz
post Dec 16 2020, 08:32 PM
Post #1698
Gently pulling from the engine side and pushing from the tunnel side, and here it comes.
bkrantz
post Dec 16 2020, 08:33 PM
Post #1699
And fully through, with the grommet seated.
But--THIS WAS A MISTAKE--see lower down.
bkrantz
post Dec 16 2020, 08:35 PM
Post #1700
Now feeding things through the hole in the forward engine shelf. This time the big plug goes first.
- Lo-Fi Version Time is now: 27th November 2024 - 11:44 PM
