Rebuiding Inside-out |
bkrantz |
Dec 19 2020, 07:53 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Then the stud by the battery. Before...
Attached thumbnail(s) |
bkrantz |
Dec 19 2020, 07:54 PM
After.
bkrantz |
Dec 19 2020, 07:55 PM
And the stud for the transaxle grounding strap.
bkrantz |
Dec 19 2020, 07:57 PM
OK, ready to start on the harness routing in the engine compartment. But first I have to repair a tear in the harness cover, just above the snorkel.
bkrantz |
Dec 19 2020, 07:58 PM
Time for some 3M rubber tape.
bkrantz |
Dec 19 2020, 08:00 PM
Better.
bkrantz |
Dec 19 2020, 08:03 PM
Right harness branch, leading to the battery.
bkrantz |
Dec 19 2020, 08:07 PM
Left branch, first to the relay board and the blower fan.
bkrantz |
Dec 19 2020, 08:08 PM
And then the lead to the trunk light.
bkrantz |
Dec 19 2020, 08:09 PM
Leaving the leads to the tail lights.
bkrantz |
Dec 19 2020, 08:10 PM
First, getting the grommet on the left side in place.
bkrantz |
Dec 19 2020, 08:11 PM
And then arranging the harness to the lights.
bkrantz |
Including the license plate lights.
bkrantz |
Dec 19 2020, 08:18 PM
I also went back to the passenger compartment, to sort out the wire routing for the parking brake handle switch. The tab for the connector will be on the inside of the cross brace.
bkrantz |
Dec 19 2020, 08:20 PM
Here's my planned routing (but inside the cross brace). Looks like enough wire.
bkrantz |
Dec 19 2020, 08:21 PM
To fish the lead, I used a length of welding wire, starting from the center tunnel.
bkrantz |
Dec 19 2020, 08:22 PM
The end popped out the switch hole on the first try! Luck is better than skill?
bkrantz |
Dec 19 2020, 08:23 PM
That made it easy to pull the switch lead.
djway |
Dec 19 2020, 09:33 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
This whole thing has left me feeling WIRED (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/smile.gif)
bkrantz |
Dec 20 2020, 08:43 PM
This whole thing has left me feeling WIRED (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/smile.gif) You and me both. Between disconnecting and removing the harness, cleaning, testing, and repairing it, and now installing it, playing with wires has consumed at least a month! |
Lo-Fi Version | Time is now: 28th November 2024 - 03:38 AM |
