Rebuiding Inside-out |
bkrantz |
Dec 20 2020, 08:46 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
More work on the front harness today, getting things in place including grommets for both the leads to the fog lights and horns, and to the head lights.
Attached thumbnail(s) |
bkrantz |
Dec 20 2020, 08:47 PM
Right side in place, except for the turn signal lead.
bkrantz |
Dec 20 2020, 08:48 PM
Fog light and horn leads out the front.
bkrantz |
Dec 21 2020, 08:14 PM
Getting close to final harness location, with new plastic tubing to cover the body tabs.
And I think I have the front left correct now. Attached thumbnail(s) |
bkrantz |
Left side under the cowl.
bkrantz |
Dec 21 2020, 08:15 PM
Left side of trunk.
bkrantz |
Dec 21 2020, 08:16 PM
Left side of engine compartment.
bkrantz |
Dec 22 2020, 07:58 PM
Finishing up tying down the harness, with the double tabs along the center tunnel.
bkrantz |
And under the driver side of the dash.
bkrantz |
Dec 23 2020, 08:58 PM
Lining for front brace openings to protect wires.
bkrantz |
Dec 23 2020, 08:59 PM
Brake line day!
Matching the new SS lines from PMB with the old sections. Attached thumbnail(s) |
bkrantz |
Dec 23 2020, 09:01 PM
Cleaning threads.
bkrantz |
Dec 23 2020, 09:04 PM
Rebuilt pressure regulator valve, also from PMB, and first connection.
bkrantz |
Dec 23 2020, 09:05 PM
Right rear line.
bkrantz |
Left rear line.
bkrantz |
Dec 23 2020, 09:06 PM
I need the T-junction for the top connection.
bkrantz |
Dec 23 2020, 09:07 PM
Short connection from the front of the tunnel line to the MC.
bkrantz |
Dec 23 2020, 09:08 PM
Front right line.
bkrantz |
Dec 23 2020, 09:09 PM
Front left line.
bkrantz |
Dec 23 2020, 09:12 PM
Another task: the frunk release. New cable housing, fed into the steel dash tube--a tight fit.
Lo-Fi Version | Time is now: 28th November 2024 - 03:52 AM |
