Rebuiding Inside-out |
bkrantz |
Dec 28 2020, 08:05 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Finishing up the relay board. The potting compound looks pretty solid after 36 hours.
And some leaks, from over-filling. Attached thumbnail(s) |
bkrantz |
Dec 28 2020, 08:06 PM
Compound leaked through the side notches, and onto one of the 12-pin sockets.
bkrantz |
Dec 28 2020, 08:07 PM
And the compound found more leak points, including the pins of the other 12-pin socket.
bkrantz |
Dec 28 2020, 08:08 PM
And the 3-pin socket, and one tab for the fuses.
bkrantz |
Dec 28 2020, 08:10 PM
And the 4-tab socket. Damned stuff was very sneaky.
bkrantz |
Dec 28 2020, 08:11 PM
At least the wax in the big holes worked.
bkrantz |
Dec 28 2020, 08:12 PM
And was easy to clean out with a tooth pick, Q-tip, and 3M solvent. I also scraped the compound off the other pins and tabs where it leaked through.
bkrantz |
Dec 28 2020, 08:16 PM
Ready to go!
A few lessons: To fill the underside takes 70-75 ml. Any more will overflow. The wax worked to fill the big holes, but a thin compound will find a way through other small holes. Attached thumbnail(s) |
bkrantz |
Dec 28 2020, 08:18 PM
One more task done today: a new shift rod bushing in the firewall.
bkrantz |
Dec 28 2020, 08:21 PM
This was a bit difficult to install. I tried pressing with a 2x4 levered against the car dolly frame without success. With a step-down spacer and big hammer, I was able to get it most of the way in, and finished with a pry tool against the inner lip.
bkrantz |
Dec 29 2020, 07:40 PM
Next, mounting new air deflectors.
mb911 |
Dec 29 2020, 07:42 PM
914 Guru Group: Members Posts: 7,280 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
@bkrantz there was something that left here today for your project.
bkrantz |
Three holes on the right side, that match the center and end holes on the deflector.
bkrantz |
Dec 29 2020, 07:45 PM
And 3 holes on the left. Note the parking brake tube blocks the left end hole on the deflector. Instead, the deflector has a 4th hole offset from the left end.
bkrantz |
Dec 29 2020, 07:48 PM
The bolts screw into under-sized holes in the plastic deflectors. It helps to "thread" these holes before mounting.
bkrantz |
Dec 29 2020, 07:49 PM
Left side in place.
bkrantz |
Dec 29 2020, 07:50 PM
And right side.
bkrantz |
Dec 29 2020, 07:53 PM
Note the factory manual has a page about mounting the deflectors.
bkrantz |
Dec 30 2020, 07:56 PM
A couple of weeks ago, before installing the wiring harness, I added a switch (from CarMagic) for a new washer pump to the steering column sub-harness.
I had also ordered a plug connector so the switch can detach from the harness if I ever need to pull the column control stalk module. Here is the connector installed. Attached thumbnail(s) |
bkrantz |
Half the connector stays with the harness.
Lo-Fi Version | Time is now: 28th November 2024 - 07:39 AM |
