342 Pages V « < 91 92 93 94 95 > »
> Rebuiding Inside-out
bkrantz
post Dec 30 2020, 07:57 PM
Post #1841
The other half stays with the switch, which needs to be installed.
bkrantz
post Dec 30 2020, 08:02 PM
Post #1842
Here's the column control module, with the original washer valve, operated by the right lever. IMO not the best idea to route washer fluid into the passenger compartment, through the steering column, and around electrical components.
bkrantz
post Dec 30 2020, 08:05 PM
Post #1843
The CarMagic switch replaces the fluid valve, but the end of the switch plunger is narrow, unlike the head on the valve plunger.
bkrantz
post Dec 30 2020, 08:07 PM
Post #1844
I decided to cut off the narrow end of the switch plunger, so the equally narrow actuator has a bigger contact target.
bkrantz
post Dec 30 2020, 08:10 PM
Post #1845
To make this work, I need to get the switch to sit further into the module, and so drilled a hole large enough for the flange to mount flush onto the module surface.
bkrantz
post Dec 30 2020, 08:13 PM
Post #1846
With the switch mounted, I checked the function. The circuit is open, until pulling the lever pushes the plunger, and closes the circuit.
jaredmcginness
Post #1847
You’ve left no bolt un-turned!!!
bkrantz
post Dec 30 2020, 08:14 PM
Post #1848
Last detail: the mounting flange for the switch protrudes beyond the module edge. I trimmed this with a utility knife.
bkrantz
post Dec 30 2020, 08:15 PM
Post #1849
Just a small air gap in "resting" state.
bkrantz
post Dec 30 2020, 08:18 PM
Post #1850
And when the wiper/washer lever is pulled, it pushes the switch plunger all the way in.
bkrantz
post Dec 30 2020, 08:19 PM
Post #1851
Control module inserted into steering column housing, ready for future installation.
djway
post Dec 31 2020, 12:39 AM
Post #1852
Very cool on the pump switch.
I have been making that mod to VWs for a long time.
I recently did it to the Pushbuttons on my Notchback. On my old Ghia I converted the flasher arm to work on the pump, high low beams are on the floor.
I know what I am doing to the 914 now, you are an inspiration (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Dec 31 2020, 05:49 AM
Post #1853
QUOTE(djway @ Dec 31 2020, 01:39 AM) *
Yes, the original design here was weak, from sourcing pressurized air from the spare tire to the switch. It's a miracle we have survived for the past 50+ years
btw, great work. what is the projected completion date?
wonkipop
post Dec 31 2020, 06:44 AM
Post #1854
@bkrantz
just read your thread from wo to go over a coupla beers since new years been cancelled here.
my hats off to you.
incredible job.
if you want a detail, the air deflectors bolt up with the bolt from below.
only know this because i stared at them doing the "fool" lines on my car.
they have not been off my car.
not picking on you mate, just nudging your masterpiece.
its a beauty.
i cannot believe the level some of you guys get to with the cars.
and the level this one is being taken to.
its so good to see 914s given this level of love.
correction - you have got those bolts right, i just went out in the garage and looked at mine. i was having a beer induced dislexic moment probably caused by memory of viewing from hoist view below. i remember the flaps are weird, like the bolt goes into the rubber/plastic flap - because i had to undo one to mess around with a fuel line. could not believe no nut was involved.
ignore the idiot.
bkrantz
post Jan 2 2021, 09:27 AM
Post #1855
Thanks, guys. Fun and therapeutic to share (and I have gained much from what others have posted).
I hate thinking about completion dates, but still can't help myself. Some days things go well and quickly, and I imagine just another month or two. Other days, with problems or delays getting parts--or just uncertainty about how I want to do things--I see years of work ahead.
More rationally, I would like to be at least 95% done and drivable by Sept 1 2021. We have our annual big local car show on Labor Day, and it would be great to have my car ready.
bkrantz
post Jan 2 2021, 09:29 AM
Post #1856
A few days ago, I made more progress with brakes, after getting parts like the crush washers for the MC banjo connection. I also cleaned the paint from the front MC output surface.
bkrantz
post Jan 2 2021, 09:30 AM
Post #1857
I also got the angled grommets for the brake fluid supply lines.
bkrantz
post Jan 2 2021, 09:31 AM
Post #1858
And popped these in place.
bkrantz
post Jan 2 2021, 09:32 AM
Post #1859
Now I installed the MC "for real".
bkrantz
post Jan 2 2021, 09:34 AM
Post #1860
I also got and installed the circular retaining clips for the tunnel brake line grommets. Not exactly a tight fit.
- Lo-Fi Version Time is now: 28th November 2024 - 09:34 AM
