bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,320 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Started surgery on the receiver car. Removed the headlight box and the forward part of the inner fender. Lots of metal work to do on the floor corner.
Attached thumbnail(s) ![]() |
bkrantz |
Here are the parts removed. I will reuse the circular brace.
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Are you still using your Fein for the cutting? That looks great. Looking forward to seeing how you make out on straightening the boogers. (IMG:style_emoticons/default/popcorn[1].gif)
bkrantz |
The Fein works best where I can cut from an exposed edge, and through a single layer. I also reach for a Rigid reciprocating saw, and a cut-off wheel on a grinder.
bkrantz |
First pass at reforming the floor corner.
bkrantz |
And progress on the rear, removing the rear panel so I can repair the inner-outer fender seems and get the corners right for the replacement floor section.
bkrantz |
Left corner detail. Pretty nasty work done when the original rear panel was replaced.
bkrantz |
Quick adjustments of the inner fender corners, left:
bkrantz |
and right:
bkrantz |
Now the panel fits.
bkrantz |
Back at the front, I am probably done working the floor corner, and got the front panel end mostly back in shape.
bkrantz |
And started to dissect the donor clip. All I need now is the inner fender wall and headlight box. I will keep the vertical brace attached at least until I can check the fit.
Bad news is some local rust that will have to be patched before it can all go together. Attached thumbnail(s) ![]() |
bkrantz |
Here's how the front corner started. I feel pretty good about what I was able to do.
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,655 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Impressive ! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beer.gif)
bbrock |
(IMG:style_emoticons/default/pray.gif) Nice work!
bkrantz |
Thanks, everyone.
Donor part down to inner fender, headlight box, and vertical brace. I need to repair some local rust but will wait until I cut and fit the fender wall splice. Attached thumbnail(s) ![]() |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Looking good there Bob.
bkrantz |
Thanks, Doug. I am in deeper than I wanted, but kinda enjoying it so far.
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,268 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Nice work and skills. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 3rd April 2025 - 08:28 AM |
