342 Pages V « < 102 103 104 105 106 > »
> Rebuiding Inside-out
bkrantz
post Jan 23 2021, 08:21 PM
Post #2061
Bracket installed inside the fender, wires connected, and boot attached.
bkrantz
post Jan 23 2021, 08:24 PM
Post #2062
Going through the parts I removed in 2019, I found only one original screw for the lens. The PO had used a variety of other hardware.
bkrantz
post Jan 23 2021, 08:25 PM
Post #2063
Anyway, one lens in place with one screw looks good to me.
bkrantz
post Jan 23 2021, 08:27 PM
Post #2064
I also got a new tool, an official Porsche ball joint retaining ring wrench.
bkrantz
post Jan 23 2021, 08:28 PM
Post #2065
This socket has tabs that exactly fit the notches in the ring.
bkrantz
post Jan 23 2021, 08:41 PM
Post #2066
Back to my set up with torque wrench and floor jack. This time I was able to get to 25 kg-m without the socket slipping.
bkrantz
post Jan 23 2021, 08:43 PM
Post #2067
And then install a new tab washer.
bkrantz
post Jan 23 2021, 08:45 PM
Post #2068
Other things received: modified CV joints from PMB. These have splines that actually fit the 914-4 shafts.
bkrantz
post Jan 23 2021, 08:46 PM
Post #2069
I restored the trunk light.
bkrantz
post Jan 23 2021, 08:47 PM
Post #2070
And installed it.
bkrantz
post Jan 23 2021, 08:49 PM
Post #2071
And I started on installing the relocated fuel pump. This might go under the tank, inside the body shell.
bkrantz
post Jan 23 2021, 08:50 PM
Post #2072
To check for clearance, I lowered the gas tank into place.
bkrantz
post Jan 23 2021, 08:52 PM
Post #2073
There might be space, but this location will probably require removing the tank to access the pump. The other option is within the steering cavity, on the bottom of the body.
bkrantz
post Jan 23 2021, 08:55 PM
Post #2074
One other project started: painting the parts for the headlights. I found a semi-gloss gray Rustoleum spray that is pretty close to original, applied over self-etching primer.
ndfrigi
post Jan 23 2021, 09:05 PM
Post #2075
nice you’re able to fix your issue attaching pictures. I do follow your build thread and learning a lot from it. Thanks again!
bkrantz
post Jan 24 2021, 07:58 PM
Post #2076
More work on mounting the fuel pump. I am still not sure where, but I favor under the tank and inside the body cavity. To check for clearance, I made a template to show the position of the bottom of the tank.
bkrantz
post Jan 24 2021, 07:59 PM
Post #2077
Looks like the stock pump mount will fit here.
bkrantz
post Jan 24 2021, 08:00 PM
Post #2078
Clearance check.
bkrantz
Post #2079
Possible location.
bkrantz
post Jan 24 2021, 08:04 PM
Post #2080
In the spirit of playing with as many different things as possible, I also pulled out the trim and vinyl for the targa hoop. This lower strip is the new Porsche part, which, like some others have mentioned, has a slightly different curve radius at the rear end. I marked the upper edge with a dry-erase marker.
- Lo-Fi Version Time is now: 28th November 2024 - 09:37 PM
