bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
And then the right side, which took about 30 minutes--after I spent 2 hours on the left.
Attached thumbnail(s) ![]() |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Looking way too nice there Bob.
Hope you are smiling when the car goes from looking like the ultimate garage queen to looking like a well worn daily driver. Ha Really great work. |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
wow! beautiful! keep up the good restoration of your car!
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
And then the right side, which took about 30 minutes--after I spent 2 hours on the left. Paint the brake rotor hubs with some good hi-heat black paint ... helps to dissipate heat and to keep them from rusting ... (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-23343-1613096830_thumb.jpg) |
bkrantz |
Thanks, guys.
Doug, stop causing trouble. Mark, sounds like a good idea. |
bkrantz |
I opened the box of small painted parts and got out the headlight eyebrows.
bkrantz |
And new rubber mounting grommets. How hard can this be?
bkrantz |
First attempt looks pretty good.
bkrantz |
But with the holes lined up, the outer edge sits high compared to the fender. (Yes, the front is not aligned but the eyebrow kept moving before I took the photo.)
bkrantz |
After a bit of bending to shift the side tab with the hole upward, the upper surfaces align (and the front does look off in the photo, but the damned thing moved again). Unfortunately, the bending cracked and flaked the paint in a few spots, so I have to touch that up before mounting the eyebrows.
bkrantz |
Same story on the right side. I could swear that I checked the fit of the eyebrows before taking the car to the paint shop.
bkrantz |
Between paint coats, I got out the front window channel from the right door, that I plan to use again.
bkrantz |
But like all the other silver trim, the PO painted this black--after some sanding.
bkrantz |
Here's where the sanding ends, compared to the original finish that was protected inside the door.
bkrantz |
I did get a buffing kit from Eastwood, but first I need to finish-sand the PO section--after I remove the anodizing.
bkrantz |
I did try sanding first, but the anodizing is tough stuff. So I tried the standard home garage approach, and borrowed the oven cleaner spray from the kitchen.
bkrantz |
I tested it on the lower section, and then went ahead and sprayed the upper section. I let the first treatment sit for 30 minutes with a bit of brushing.
bkrantz |
It looked splotchy, so I gave it another spay and let it sit 20 more minutes. I washed off the oven cleaner, and the finish looked uniformly duller and a bit darker. The OP sanding is still visible.
bkrantz |
Now additional sanding was easy. Here it is after 320 grit.
bkrantz |
And after wet sanding with 600 grit.
Lo-Fi Version | Time is now: 26th June 2024 - 12:20 AM |
