Rebuiding Inside-out |
bkrantz |
Mar 7 2021, 07:24 PM
914 Guru Group: Members Posts: 7,845 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Speaking of the interior, I made some progress towards that today and tackled the dash top. I masked off the new paint near the areas to get adhesive. More to come about the paint and adhesive...
Attached thumbnail(s) |
bkrantz |
Mar 7 2021, 07:25 PM
First step was to spray the dash and underside of padding with Weldwood Landau adhesive.
bkrantz |
Mar 7 2021, 07:26 PM
Padding in place, with lots of overhang on all sides. I started adhering in the center, and then pulled the paper out gradually on both sides.
bkrantz |
Mar 7 2021, 07:28 PM
Padding all stuck down. Very good adhesion.
bkrantz |
Mar 7 2021, 07:29 PM
And then trimmed all around with a new utility blade.
bkrantz |
Mar 7 2021, 07:30 PM
After that, I got out the liquid Weldwood. I decided to do what the factory did and glue down only the edges of the vinyl.
bkrantz |
Mar 7 2021, 07:32 PM
Test fitting the vinyl. Again, lots of overlap.
bkrantz |
Mar 7 2021, 07:36 PM
I taped the ends to add some gentle tension.
Then I first glued along the inside edge, about 1/2 inch below the raised area (and foam padding). Sorry, no picture. I brushed adhesive onto the dash and the edge of the vinyl. On the first attempt, I realized the adhesive solvent was lifting the black paint (Rustoleum semi-gloss rattle can). I had to clean that up with acetone, and apply another coat of adhesive. Attached thumbnail(s) |
bkrantz |
Mar 7 2021, 07:38 PM
Once the inner edge was stuck on, I brushed adhesive onto the leading edge of the vinyl and the underside of the dash.
bkrantz |
Mar 7 2021, 07:42 PM
While smoothing and gently stretching, I folded the vinyl over the edge and stuck it to the underside. For the defroster vent inner corners, I duplicated the cuts on the original vinyl (bisecting the corner angles).
bkrantz |
Mar 7 2021, 07:43 PM
Cleaned up and almost ready to install.
bkrantz |
Mar 8 2021, 08:32 PM
Next step on the dash: installing the front plate. I used 3M high strength double-sided auto adhesive tape.
bkrantz |
Mar 8 2021, 08:33 PM
Stuck on, located by the holes for switches, etc.
bkrantz |
Mar 8 2021, 08:34 PM
Dash is starting to look like a dash.
bkrantz |
Mar 8 2021, 08:36 PM
I pulled out the original glove box. Its in pretty good shape, including the inner flocking, but has a bit of a bow along the front edge.
bkrantz |
Mar 8 2021, 08:37 PM
I let the fiberboard soak and absorb some water, and then clamped the bowed edge--I hope it dries straight.
djway |
Mar 8 2021, 10:05 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I let the fiberboard soak and absorb some water, and then clamped the bowed edge--I hope it dries straight. I did one by holding it over a steaming pot of soup (IMG:style_emoticons/default/blink.gif) |
gereed75 |
Mar 8 2021, 10:08 PM
Senior Member Group: Members Posts: 1,264 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I have thought of the thinned penetrating epoxies as a means of repairing fiberboard. They are designed to repair dry rotted wood by soaking in and then setting.
Seems would work on fiber board also. Get Rot is a brand name Among others https://www.amazon.com/Boat-Git-Rot-Penetra...998&sr=8-30 Have planned to use it to repair/re-enforce my back pad when I get around to it. Anyone have any experience with it? |
bkrantz |
Mar 9 2021, 08:54 PM
I let the fiberboard soak and absorb some water, and then clamped the bowed edge--I hope it dries straight. I did one by holding it over a steaming pot of soup (IMG:style_emoticons/default/blink.gif) Come on, you have to be more specific--what kind of soup? |
djway |
Mar 9 2021, 10:37 PM
I let the fiberboard soak and absorb some water, and then clamped the bowed edge--I hope it dries straight. I did one by holding it over a steaming pot of soup (IMG:style_emoticons/default/blink.gif) Come on, you have to be more specific--what kind of soup? Large pot homemade garden vegetable. (IMG:style_emoticons/default/chowtime.gif) |
Lo-Fi Version | Time is now: 2nd July 2024 - 07:53 PM |
