bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,855 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Then sprayed DAP Weldwood Landau adhesive on the targa top.
Attached thumbnail(s) ![]() |
bkrantz |
And the back side of the vinyl.
bkrantz |
With the adhesive tacky, I put it on top of some masking paper sheets while I got it in position.
bkrantz |
Rubbed down and trimmed.
bkrantz |
For the sail, I masked off the panel.
bkrantz |
Test fitting the vinyl, and making reference location marks.
bkrantz |
More DAP spray on the sail...
bkrantz |
And on the vinyl.
bkrantz |
Vinyl stuck on, smoothed out, and initial trim.
kroelofsen |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe ![]() ![]() |
(IMG:style_emoticons/default/piratenanner.gif) that looks nice... have to do this myself somewhere this year...
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,390 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Looks so nice. Keep the posts coming.
bkrantz |
Thanks, guys. Not a hard job but it takes patience and luck.
bkrantz |
Got the left sail done.
bkrantz |
And installed the lower trim. This is a new (repro?) Porsche piece, but took some tweaking around the curve to get it to lie flat.
bkrantz |
Same on the right side.
bkrantz |
Test fit of the original targa pad. Its in pretty good shape, except for a couple of small cracks and a slight bulge in the middle. Have to see if I can improve this.
bkrantz |
I got out all the interior padded trim pieces. Got some clean-up to do.
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
looking soooo good!! fun to watch others do this, i took almost same approach for the sail panel installation with the reference marks for alignment , i have done mine several time and it took the 3rd to do it right and look great. it’s almost a 2 person job to get that long top targa bar piece in place, did you have help? love the attention to detail, and that black/yellow combo is awesome! did you rebuild the fresh air defrost fan housing? 914rubber now has all the parts to do it.
bkrantz |
looking soooo good!! fun to watch others do this, i took almost same approach for the sail panel installation with the reference marks for alignment , i have done mine several time and it took the 3rd to do it right and look great. it’s almost a 2 person job to get that long top targa bar piece in place, did you have help? love the attention to detail, and that black/yellow combo is awesome! did you rebuild the fresh air defrost fan housing? 914rubber now has all the parts to do it. Thanks, doc. I was alone, but got the position right with the inter-leaved paper sheets (and some good luck). The color combo is what I dreamed about, and happy to see it real--and I still like it. I cleaned, rebuilt, and tested my fresh air fan and housing, with the 914Rubber kit. That should be going in soon. |
bkrantz |
I installed the steering shaft, after I realized this should have gone in before the dash. It was a bit fiddly, but I got it. I was waiting until I got the carpet installed, but that will be a while since I have not made up my mind about color.
Lo-Fi Version | Time is now: 5th July 2024 - 02:31 AM |
