DdHavtech |
Newbie ![]() Group: Members Posts: 7 Joined: 21-March 18 From: Ellicott City, MD Member No.: 21,993 Region Association: None ![]() |
On the sail panel vinyl - what is the correct way to trim it and not scratch into the nice new paint?
Very nice. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,863 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
On the sail panel vinyl - what is the correct way to trim it and not scratch into the nice new paint? Very nice. I used several new single-edge razor blades, and cut width moderate pressure--trying to cut the vinyl and only score the paint. I thought about pre-cutting the lower edge, but could not figure out how to make sure I glued it on exactly right. |
bkrantz |
A productive couple of hours today. I started with the fresh air control panel. It looks a little shabby but I cleaned and tested all the contacts.
Attached thumbnail(s) ![]() |
bkrantz |
Control panel in place, but at first I could not recall how to keep it in place.
bkrantz |
Then I found (and remembered) the single bolt that goes through a bracket on the back side of the control panel and into the bulkhead. Also note the wires connected.
bkrantz |
And the 3 cables fed through the 3-hole rubber grommet.
bkrantz |
Now its time for the dreaded fresh air box. I rebuilt this with the 914 Rubber kit, tested all the circuits, and have the new upper rubber gasket and plastic grill.
bkrantz |
Now I know I am getting old. I got tired of climbing into the frunk for better access, so I got out my ladder.
bkrantz |
OK, step one was attaching the control cable (from upper lever) to the box, and adjusting the position to match the lever throw.
bkrantz |
Then the cable connector. I replaced the broken one that the PO had duct-taped in place.
bkrantz |
Ready for my first attempt, with the rubber gasket and grill in place.
bkrantz |
1st attempt: I muscled the box into place but the gasket and grill were no longer in position, and no chance of getting my fingers in close to fix that. Notice the dirty foot print on the right.
bkrantz |
2nd (or maybe 3rd) attempt: I used some long zip ties to hold the gasket and grill in place.
bkrantz |
I had enough muscle left to pull up on the cowl panel while pushing the box into place. So old, but not too old. (IMG:style_emoticons/default/aktion035.gif)
bkrantz |
Now for the last part: lifting the box against the new rubber gasket to align the side holes with the mounting brackets and get the bolts in place. I got the right side in with more muscle power, but could not get the left side without assist. For that, I used a 2x4 lever and my wonderful wife. I pulled on the lever while pushing the box to the rear, and she got the bolt started. Note that I pried against the lower corner of box, and not against the drain outlet.
bkrantz |
All I had to do was snip the zip ties and pull them free, with some soapy water to help.
bkrantz |
Success! At least until I test it all later on.
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
You better paint these two spots black. Aren't there a couple of plastic vent outlets that fit in there? (IMG:style_emoticons/default/confused24.gif) After I mounted the front plate to the dash frame, I cut out all the holes in the dash face, without thinking. On my car, switches fill the 3 holes left of the steering wheel, and the cigarette lighter goes in the big hole on the right. But now I have 2 extra holes! (IMG:http://www.914world.com/bbs2/uploads/post-23343-1615602562_thumb.jpg) Maybe you could install a couple of auxiliary electrical toggle switches with the bomber type safety covers to fill the extra holes... ? (They look cool) (IMG:style_emoticons/default/aktion035.gif) ![]() |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Had to chuckle a bit when I saw the step ladder.
Thank goodness I've got long arms and did this all while leaning over the fenders. Ha Yeah, that 2 by 4 brought back some memories. And the dreaded screen on the top of the airbox. Now if you just don't have to remove the airbox 2 more times like I did for various stupid reasons. Looking good there Bob. And for one of the extra holes in the dash....might I suggest a rear fog light. (IMG:style_emoticons/default/wink.gif) ![]() ![]() For the other, you could add one of those slick dual USB charging ports. ![]() |
CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
Lo-Fi Version | Time is now: 7th July 2024 - 11:28 PM |
