Rebuiding Inside-out |
bkrantz |
May 3 2021, 07:25 PM
914 Guru Group: Members Posts: 8,066 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Then time for the cam bearings. I have a full set, plus an extra half with thrust edges.
Attached thumbnail(s) |
bkrantz |
May 3 2021, 07:26 PM
Cam bearings installed in the right case half.
bkrantz |
May 3 2021, 07:27 PM
Cam installed.
bkrantz |
May 3 2021, 07:28 PM
Gears indexed--probably the easiest step in the engine build.
bkrantz |
May 3 2021, 07:29 PM
And cam bearings in the left case half. This is where the extra half cam thrust bearing goes, including the tab.
That should be everything before putting the case together for real. I will not install the distributor drive gear since I plan to run an electronic ignition with no dizzy. Attached thumbnail(s) |
kroelofsen |
May 4 2021, 04:55 AM
Member Group: Members Posts: 100 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe |
bkrantz |
May 4 2021, 06:56 PM
Bolted and torqued. Hi, I did exactly the same but later had to remove the washers as the bolt heads were touching the oil pump... check it before joining the 2 engine halves... @kroelofsen , Thank you!!! You saved me hours of aggravation and expense. I owe you at least a six-pack. See below for what I found. |
bkrantz |
May 4 2021, 06:57 PM
I got out my new oil pump, a Shradek 26mm.
bkrantz |
May 4 2021, 06:59 PM
And slid the pump into place, with the cam as I left it yesterday, with the washers on the gear bolts.
bkrantz |
May 4 2021, 07:00 PM
And found contact between the bolt heads and the pump body.
bkrantz |
May 4 2021, 07:02 PM
So I pulled the cam R&R'd the bolts to omit the washers. Just high-temp red Loctite to hold the bolts in place.
bkrantz |
May 4 2021, 07:03 PM
Cam and pump back in place.
bkrantz |
May 4 2021, 07:05 PM
Now there is daylight between the bolt heads and the pump.
bkrantz |
I measured .042 inch clearance.
bkrantz |
May 4 2021, 07:07 PM
But then found another problem. The rotor stud is bottoming out against the cam end, and so does not sit completely inside the pump body.
bkrantz |
May 5 2021, 07:55 PM
Checking the drive rotor, the shaft is not pushed all the way into to gear.
bkrantz |
May 5 2021, 07:56 PM
A quick visit to the hydraulic press...
bkrantz |
May 5 2021, 07:57 PM
Now the shaft is flush.
bkrantz |
May 5 2021, 07:58 PM
I also checked the clearance of the oil pump case against the end of the cam. The depth to the cam end is 38.85 mm.
bkrantz |
May 5 2021, 08:00 PM
The depth of insertion of the pump case is 38.84 mm--no clearance!
Lo-Fi Version | Time is now: 27th September 2024 - 09:21 PM |
