Rebuiding Inside-out |
bkrantz |
May 5 2021, 08:02 PM
914 Guru Group: Members Posts: 8,066 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
The deepest part of the case is the protrusion around the drive shaft. Since I seated the shaft further into the gear, the base of the notch is now inside the protrusion.
Attached thumbnail(s) |
bkrantz |
May 5 2021, 08:04 PM
I filed off the end of the protrusion (easy, since the pump case is aluminum). I took off about 0.75 mm (0.03 inch).
bkrantz |
May 5 2021, 08:05 PM
Now the base of the notch extends beyond the case.
bkrantz |
May 5 2021, 08:08 PM
Now the pump sits tight into the engine case, with about 0.75 mm clearance with the cam end (without any gaskets).
bkrantz |
May 5 2021, 08:09 PM
And the pump gears sit inside the case and do not protrude.
bkrantz |
May 5 2021, 08:10 PM
To celebrate I cleaned up the case through-bolts, washers, and nuts.
bkrantz |
May 6 2021, 07:13 PM
I found my left-over Dynamat, and decided to use some scraps on the bulkhead under the dash, since the relocated fuel pump is on the other side of this sheet metal.
bkrantz |
May 6 2021, 07:14 PM
After about 20 minutes. It might not matter much, but I would rather not hear the pump.
bkrantz |
May 6 2021, 07:20 PM
I then got on to installing the main gauge panel.
I finally got the LED bulbs for the indicator and back lights. Attached thumbnail(s) |
bkrantz |
May 6 2021, 07:21 PM
First I replaced all the bulbs in the common back-light string.
bkrantz |
May 6 2021, 07:25 PM
Here's my references for wire locations: photos I took in October 2019 (never enough) and the color schematics.
bkrantz |
May 6 2021, 07:26 PM
Ready to start!
bkrantz |
May 6 2021, 07:28 PM
And then, done. I was able to find places for all the wires, and wires for all the places.
bkrantz |
May 6 2021, 07:30 PM
And then I installed the gauge panel.
I have a couple more things to check, and then I plan to connect a battery and see if some things work. Attached thumbnail(s) |
Kansas 914 |
May 6 2021, 07:48 PM
bkrantz |
May 6 2021, 08:06 PM
And then, done. I was able to find places for all the wires, and wires for all the places. Make sure you don't put an LED in the "GEN" socket. The alternator needs a load to charge. I think you are already aware of that. Hi, Mike. I should have mentioned that--one of the few things I remembered to do (or not to do) the first time. |
Puebloswatcop |
May 7 2021, 07:08 AM
Senior Member Group: Members Posts: 1,395 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Love following your build. It has been full of the small details that plague these builds along with your solutions to the problems. Thanks for sharing.
930cabman |
May 7 2021, 01:00 PM
Advanced Member Group: Members Posts: 3,546 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Love following your build. It has been full of the small details that plague these builds along with your solutions to the problems. Thanks for sharing. +1, tons of details most of which are never addressed (myself included) Great job and thank you for documenting. Is there an end date for the build? |
bkrantz |
May 7 2021, 07:15 PM
Love following your build. It has been full of the small details that plague these builds along with your solutions to the problems. Thanks for sharing. +1, tons of details most of which are never addressed (myself included) Great job and thank you for documenting. Is there an end date for the build? Thanks, guys. I was aiming for September, since we have our big annual car show on Labor Day (except last year). But now I have some other things showing up on my calendar. And even if I had nothing else, it would be a challenge. Since winter can start here in October, I think I should pace this into next spring. |
bkrantz |
May 7 2021, 07:19 PM
I got some 50 mm hose, that almost matches the 60 mm stuff from 914 Rubber. It is also a bit stiffer.
Lo-Fi Version | Time is now: 27th September 2024 - 09:21 PM |
