343 Pages V « < 14 15 16 17 18 > »
> Rebuiding Inside-out
bkrantz
post Feb 29 2020, 10:13 PM
Post #301
Now time to move on. Here is the middle layer patch for the top of the sill, final fit.
bkrantz
post Feb 29 2020, 10:15 PM
Post #302
And welded in place.
bkrantz
post Feb 29 2020, 10:16 PM
Post #303
And here is the top layer patch, nearly fitted.
bkrantz
post Mar 1 2020, 09:36 PM
Post #304
Started welding on the last layer, beginning with the flange against the inner fender wall. Nice to have the car on the rotisserie, so I could weld with the flange and fender wall horizontal.
bkrantz
post Mar 1 2020, 09:40 PM
Post #305
I ground down the welds along the flange and they looked good, so went on the weld the main part of the patch. Mostly straight-forward, except along the seam against the remaining original pitted metal. That led to some more ugly welds.
bkrantz
post Mar 1 2020, 09:42 PM
Post #306
I still have to grind this down and check the weld success, but I am happy to be close to done on closing up the hell hole, only 6 months after I cut a hole in the top to explore for internal rust.
tygaboy
post Mar 1 2020, 10:56 PM
Post #307
A bit of (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
And now some (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Super job! Isn't it a great feeling when it's "job done"? Keep up the great work and detailed documentation.
bkrantz
post Mar 2 2020, 09:55 PM
Post #308
Thanks. Milestones are good for my mental health, as are my documentations and posts.
Anyway, here is the finished (for now) product. A bit lumpy, but it should be functional and look OK, especially after prep and paint.
bkrantz
post Mar 2 2020, 09:56 PM
Post #309
On to the firewall. Here's a cardboard template fit for the lower patch.
bkrantz
post Mar 4 2020, 08:44 PM
Post #310
Small patch cut and formed, with holes in the flanges for plug welds.
bkrantz
post Mar 4 2020, 08:45 PM
Post #311
Final fit.
bkrantz
post Mar 4 2020, 08:46 PM
Post #312
After welding and grinding. Now time for the bigger hole...
bkrantz
post Mar 4 2020, 08:47 PM
Post #313
And from the engine side.
bkrantz
post Mar 5 2020, 10:02 PM
Post #314
Spent about an hour today working on forming the upper firewall patch, including the diagonal raised ribs. Still needs more work in the complex corner on the right side.
FourBlades
post Mar 6 2020, 08:13 AM
Post #315
From Wreck to Rockin
Looking good!
You are making good progress.
John
9146C
post Mar 6 2020, 09:20 AM
Post #316
Very impressed with your fabrication work!
tygaboy
post Mar 6 2020, 09:26 AM
Post #317
Fabricationlous! (IMG:style_emoticons/default/smash.gif) Nice looking patch piece. You're making great progress. (IMG:style_emoticons/default/smilie_pokal.gif)
bkrantz
post Mar 6 2020, 06:03 PM
Post #318
Thank, guys. Just a bit of time to play body shop today. The corner fold looks better, and I am ready to trim this patch.
bkrantz
post Mar 7 2020, 09:44 PM
Post #319
Spent a couple of hours fitting the new patch. After the initial cut, I had it in and out about a dozen times--definitely trying to attain the Zen level of patience. Here it is near the end of fitting trials.
bkrantz
post Mar 7 2020, 09:45 PM
Post #320
And after tack-welding. Time for more patience.
- Lo-Fi Version Time is now: 19th April 2025 - 01:35 PM
