343 Pages V « < 15 16 17 18 19 > »
> Rebuiding Inside-out
bkrantz
post Mar 8 2020, 07:09 PM
Post #321
Welding done, and initial grinding. Might be a few spots to touch up.
bkrantz
post Mar 10 2020, 08:43 PM
Post #322
On to the last thing in the hell hole area: the right engine shelf. Here is the piece from RD.
bkrantz
post Mar 10 2020, 08:45 PM
Post #323
First fit check after my initial trim. I need only the front half of the shelf, and a bit more of the rubber seal channel.
bkrantz
post Mar 10 2020, 08:46 PM
Post #324
And after about a dozen cycles of check, trim, bend, repeat. About 90% fitted.
raynekat
post Mar 10 2020, 10:49 PM
Post #325
Looks good Bob.
bkrantz
post Mar 11 2020, 07:48 PM
Post #326
Thanks, Doug. Still lots to do on the body shell (finish the shelf, remount the front fender, straighten the rear fender and rear panel, miscellaneous brackets and braces) and then both doors and the replacement trunk lid need a bit of work.
But we do this for fun, right?
bkrantz
post Mar 12 2020, 08:25 PM
Post #327
Had a couple of hours of garage time and worked to finish the fit. I could not get both ends just right, so I tried tack welding one end and working the fit as I welded towards the other end. Seemed to work OK.
Lilchopshop
post Mar 13 2020, 08:14 AM
Post #328
Bob, I'm really enjoying your thread! Thank you for the excellent documentation! Its great to see that top-level workmanship can still be achieved without a fully-outfitted fabrication shop. This will be a great reference for me as I go through my project.
tygaboy
post Mar 13 2020, 08:42 AM
Post #329
I'm going to start calling you Bob "Dunwright".
Thanks for saving your car and installing so very much love into it. Great stuff. (IMG:style_emoticons/default/smilie_pokal.gif)
bkrantz
post Mar 13 2020, 08:36 PM
Post #330
Thanks, guys. Encouragement always helps.
bkrantz
post Mar 13 2020, 08:41 PM
Post #331
Got the engine shelf welding done. I am pretty happy with results except where I fumbled the grinder inside the groove for the rubber engine shelf seal. I will probably splice in a piece to fix this.
bkrantz
post Mar 13 2020, 08:43 PM
Post #332
On to the rest of the issues in the engine compartment. First is the right trunk hinge bracket. Grinding out the old, torn bracket resulted in a couple of small holes (and some brass from the brazing done by the PO).
bkrantz
post Mar 13 2020, 08:44 PM
Post #333
After welding the grind the holes.
bkrantz
post Mar 13 2020, 08:46 PM
Post #334
And after measuring, and re-measuring, I tack-welded the new bracket in place. I will triple-check the position tomorrow and finish the welds.
bkrantz
post Mar 13 2020, 08:48 PM
Post #335
Meanwhile, I started the next task. Both the left and right engine lid hinge brackets were torn out. The PO "fixed" these by bolting through the firewall. Left side.
bkrantz
Post #336
Right side.
bkrantz
post Mar 13 2020, 08:50 PM
Post #337
I cut out just enough to get straight edges, and did a bit of metal work to even things up. Left side.
bkrantz
Post #338
And right side. I will cut some patches tomorrow.
bkrantz
post Mar 14 2020, 08:07 PM
Post #339
When I measured the right trunk hinge bracket today, I found it to be about 1/8 inch low. So I cut off the tack welds, repositioned, measured about 5 more times, and welded it in for good (I hope). My MIG welder is acting funny, so I may grind these semi-ugly welds and redo it once I figure out what is wrong.
bkrantz
post Mar 14 2020, 08:09 PM
Post #340
Back to the engine lid hinges, here's the patch for the left side.
- Lo-Fi Version Time is now: 19th April 2025 - 01:35 PM
