bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,833 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Cover installed, with new sealing nuts.
Attached thumbnail(s) ![]() |
bkrantz |
And then the impeller hub and crank nose seal.
bkrantz |
Before installing the hub, I dressed the sealing surface with some emery paper.
bkrantz |
I also cleaned up the small Woodruff key.
bkrantz |
Seal and hub installed.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,211 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Bob, what grit did you use to clean the sealing surface of the hub? and did you use a "seal installer"
thanks |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Did you put the o-ring around the nose of the crank before installing the seal? Just backing ya up since i don't see it in the parts pic (IMG:style_emoticons/default/wink.gif)
bkrantz |
Bob, what grit did you use to clean the sealing surface of the hub? and did you use a "seal installer" thanks I used some 1000 grit emery paper. And then rinsed the hub with solvent. For the installer, I used a Jeep hub socket. Attached thumbnail(s) ![]() |
bkrantz |
Did you put the o-ring around the nose of the crank before installing the seal? Just backing ya up since i don't see it in the parts pic (IMG:style_emoticons/default/wink.gif) Thanks for the reminder, Ian--I forgot the O-ring. I think I had it for the first build attempt, but lost it in the shuffle. I just ordered a new one. I owe you one! |
bkrantz |
I also realized I forgot a couple of the oil galley plugs. Here are the two galleys on the side of the oil cooler mounting flange.
bkrantz |
And the remaining NPT plugs in the kit.
bkrantz |
After some thread sealant...
bkrantz |
Both plugs are in place.
bkrantz |
Now I have one very small plug left over. I don't see any of the small galleys that were opened and threaded.
bkrantz |
My next project is creating and installing a new oil dip stick tube, since the original was pretty beat up.
bkrantz |
I bought a 1mm and then a 0.5mm wall tube, both 8mm OD (original on the right).
bkrantz |
That was based on my measurement of the original tube main section.
bkrantz |
But the part that inserts into the engine case is larger, about 8.4mm. Now I have to figure out how to expand the base of the tubing.
930cabman |
Now I have one very small plug left over. I don't see any of the small galleys that were opened and threaded. Probably 1/8" NPT, would be installed on the face of the case near the dip stick tube. Take your time, don't get too anxious and miss a step or two. Thanks for posting, many of us are following your build |
iankarr |
Got your six (IMG:style_emoticons/default/smile.gif) though in this group that could take on other meanings! Your build is spectacular.
Lo-Fi Version | Time is now: 25th June 2024 - 04:39 PM |
