bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,320 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
After a long trip to Tucson for turkey and visiting kids, I am back home and at work on the 914. Excited to start actually putting pieces together.
Got the front corner clip rough-fitted, and was surprised that my first attempt measures pretty close to exact (comparing left and right dimensions, and compared to my new straight frunk lid). Attached thumbnail(s) ![]() |
bkrantz |
More work to do on the right end of the front panel, that was pretty banged up. I did some straightening by eye, and now have to precisely match the clip.
GTSandberg |
Member ![]() ![]() Group: Members Posts: 63 Joined: 16-August 19 From: Drammen, Norway Member No.: 23,373 Region Association: Europe ![]() |
Craftmanship and attention to details, Im in (IMG:style_emoticons/default/popcorn[1].gif)
bkrantz |
Still working the fit. Made a cardboard template from the good side, and now need to work the bad side to match (and get the splice, the front panel, and the floor to align).
bkrantz |
Work to do. Gap seen from below.
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Looking good! Do some diagonal measurements from the base of the windshield to the corner of the buckets. I had a car that was off by one inch on one side! Made fitting the headlights exciting until I realized and fixed it. Don't neglect the vertical checks as well. I have a feeling from your work that you know all that. (IMG:style_emoticons/default/biggrin.gif) John |
bkrantz |
Looking good! Do some diagonal measurements from the base of the windshield to the corner of the buckets. I had a car that was off by one inch on one side! Made fitting the headlights exciting until I realized and fixed it. Don't neglect the vertical checks as well. I have a feeling from your work that you know all that. (IMG:style_emoticons/default/biggrin.gif) John Thanks, John. The diagonal measurements (and lots more) check out. I also compared positions to the front hood (a very straight one). |
bkrantz |
More metal work, and the fit is getting closer--off by no more than a 1/16 to 3/32 inch.
bkrantz |
Last bit of mis-alignment is the outermost end of the front panel.
bkrantz |
After a few more hours today, I am claiming victory and will get on to welding soon. All the gaps and measurements are within 1/16 inch, and all the angles within 1 degree.
bkrantz |
Of course, I might tap on things a bit more, just to make things more pretty.
bkrantz |
Now starting on the rear. Weeks ago, I cut out the badly rusted rear half of the trunk floor, and also the un-rusty rear panel. That was a replacement during a PO repair, not done well. Took some surgery to undo the triple-layer seams on each side.
Here is the left side, looking not bad, except the seam and lower edges. Attached thumbnail(s) ![]() |
bkrantz |
And here is the lumpy right side. Previous repair work done quickly?
bkrantz |
First effort, left side. Almost good.
bkrantz |
And right side. Still needs work.
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
You are a wizard. (IMG:style_emoticons/default/pray.gif)
bkrantz |
Right side done enough for now.
bkrantz |
Time to start on the rear panel.
And yes, almost all the work so far has been to repair collision damage that had been repaired before. Attached thumbnail(s) ![]() |
bkrantz |
Getting back to work, and a real milestone today: actually adding metal (welded the holes and tears in various places before starting to install the front corner splice.
bkrantz |
And the first parts of the bracing for the open body. Hoping to get the front and rear done, and the car on the rotisserie by Dec 31.
Lo-Fi Version | Time is now: 3rd April 2025 - 08:29 AM |
