bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Here's the slave pulley, set up with the mounting bracket and return spring.
Attached thumbnail(s) ![]() |
bkrantz |
All together on the left throttle body.
bkrantz |
Then I got the cable stop aligned with the pulley.
bkrantz |
I also swapped out the bottom plates for the air filters, since I will not need the mounting posts for the cross-bar.
bkrantz |
Right side with the master pulley.
bkrantz |
Again, I lined up the cable stops with the pulley.
bkrantz |
Now its time for the auxiliary cable that connects the two sides.
bkrantz |
Obvious route for the cable, from right to left.
bkrantz |
But this leaves the middle hanging unsupported, which could make the ends twist downward and mess up the cable tension.
bkrantz |
So I made a small bracket to support the middle of the cable.
bkrantz |
As a straight line, the cable housing is about an inch too long.
bkrantz |
Time to get out the bike tools again, this time a cable housing shear.
bkrantz |
That leaves the housing end a bit jagged.
bkrantz |
Filed flat, so the cable housing sits even in the stop.
bkrantz |
Cable housing installed.
bkrantz |
Cross cable end on the master pulley.
bkrantz |
And on the slave side. I made a preliminary tension adjustment.
bkrantz |
Once the engine is installed, I will connect the throttle cable to the master pulley, and it should be good to go.
bkrantz |
In order to reach the right rear, the accelerator cable will need to come up through the sheet metal near the front, so I made a new 1/2 inch hole.
bkrantz |
Rubber grommet.
Lo-Fi Version | Time is now: 30th April 2025 - 07:08 AM |
