343 Pages V « < 213 214 215 216 217 > »
> Rebuiding Inside-out
bkrantz
post Dec 11 2021, 09:15 PM
Post #4281
Mounted on the left throttle body.
bkrantz
post Dec 11 2021, 09:16 PM
Post #4282
Vacuum/vent line from the cylinder heads via the anti-flashback valve.
bkrantz
post Dec 11 2021, 09:18 PM
Post #4283
I found that the notches in the plug wire brackets were too small, and pinching the wires. So I pulled off the plastic dip coating, and then filed the holes larger. I was able to slid the coating back on.
bkrantz
post Dec 11 2021, 09:19 PM
Post #4284
I stacked the plug wire brackets with a pair of hose clamps for the fuel lines on both sides .
bkrantz
post Dec 11 2021, 09:20 PM
Post #4285
For now, the fuel lines and plug wires are done.
bkrantz
post Dec 12 2021, 07:42 PM
Post #4286
Here's my SS muffler from Ben Macfarland. I need to install a SS bung for the O2 sensor. The muffler might not be ideal, since it is a bit downstream from the combustion chambers, but it is the first location where the exhaust from all 4 cylinders will mix.
bkrantz
post Dec 12 2021, 07:43 PM
Post #4287
I chose a location as far towards the center as possible, but not in the way of the muffler bracket.
Then I got out a 1 inch hole saw, and mounted the muffler on the press.
bkrantz
post Dec 12 2021, 07:45 PM
Post #4288
Ready for welding.
bkrantz
post Dec 12 2021, 07:48 PM
Post #4289
I then started the transfer of the engine from the stand onto jack stands. This turned out to be a logic puzzle as well as mechanical process.
First, I got out the engine support bar, from the almost depleted stock of powder-coated parts.
bkrantz
post Dec 12 2021, 07:49 PM
Post #4290
Bolted onto engine rubber mounts.
bkrantz
post Dec 12 2021, 07:51 PM
Post #4291
Here's part one of my two step process. Given the jacks and other stuff I have, I had to first take the weight off the stand, and then lower the engine as much as possible, i.e. about half-way. I made some scaffolding, and put my Fuchs wheels to work (purists look away).
bkrantz
post Dec 12 2021, 07:55 PM
Post #4292
After removing the stand, I lowered the engine so the support bar and the stand pivot rested on jack stands. I then pulled out my "scaffolding" and repositioned the jack now on the floor.
bkrantz
post Dec 12 2021, 07:58 PM
Post #4293
With the weight on the jack again, I added an angle iron piece to support the back of the engine.
bkrantz
post Dec 12 2021, 08:00 PM
Post #4294
I will leave the jack in place as backup, until the trans is attached and supported.
bkrantz
post Dec 12 2021, 08:01 PM
Post #4295
Last task today: unbolt the engine stand mount from the case. Ready for a clutch!
nivekdodge
post Dec 12 2021, 08:29 PM
Post #4296
QUOTE(bkrantz @ Dec 12 2021, 09:01 PM) *
If you have an engine hoist is there a safe place to bolt a chain?
Puebloswatcop
post Dec 13 2021, 05:54 PM
Post #4297
QUOTE(bkrantz @ Dec 10 2021, 08:44 PM) *
Now starting to think about where to put the control box and the relay box. The trunk is the obvious place, away from wet conditions.
Looking at the possibility of having to remove any connections i think the first picture makes more sense in mounting the control box...... But after looking at the pictures again I see that the ports are blocked either way....Maybe mount both on the upper part of the wall so they arent blocked by the jack or the inner fender.....
bkrantz
post Dec 13 2021, 08:10 PM
Post #4298
QUOTE(nivekdodge @ Dec 12 2021, 07:29 PM) *
I have one (in pieces, stashed under my big work bench). But I thought by the time I could rig up a safe attachment method and assemble the hoist, I could get the job done with my motorcycle lift.
bkrantz
post Dec 13 2021, 08:22 PM
Post #4299
QUOTE(Puebloswatcop @ Dec 13 2021, 04:54 PM) *
I am still pondering the best location. I should need to connect to the serial port during set up and tuning, so the jack would not be in the way most of the time.
bkrantz
post Dec 13 2021, 08:26 PM
Post #4300
Everything (almost) I need to get the trans ready and mounted to the engine.
- Lo-Fi Version Time is now: 29th April 2025 - 06:56 PM
