343 Pages V « < 215 216 217 218 219 > »
> Rebuiding Inside-out
bkrantz
post Dec 14 2021, 08:23 PM
Post #4321
I then explored the options for spacers, washers, and retaining clips. This would be the stock set-up.
bkrantz
Post #4322
New conical washer on the shaft, and some grease on the splines.
bkrantz
post Dec 14 2021, 08:26 PM
Post #4323
I pressed the CV onto the shaft, and then used split ring pilers on the stock type circlip.
bkrantz
post Dec 14 2021, 08:28 PM
Post #4324
But the CV center partially blocks the groove for the clip. I tried using my press to squeeze the conical washer down but that did not work.
bkrantz
post Dec 14 2021, 08:30 PM
Post #4325
The CV kits also include a thinner snap ring.
bkrantz
post Dec 14 2021, 08:31 PM
Post #4326
That fits nicely, but could be weaker.
bkrantz
post Dec 14 2021, 08:33 PM
Post #4327
I pressed the CV off the shaft.
bkrantz
post Dec 14 2021, 08:34 PM
Post #4328
bkrantz
post Dec 14 2021, 08:35 PM
Post #4329
bkrantz
post Dec 14 2021, 08:36 PM
Post #4330
And then I dug out the conical washers from the original CVs. These were already a bit flatter than the new ones, and I encouraged them to be even flatter.
bkrantz
post Dec 14 2021, 08:39 PM
Post #4331
Comparison of the flattened washer (top) and the high-relief new washer (bottom). My measurements are close to fitting with the thicker circlip.
bkrantz
post Dec 14 2021, 08:41 PM
Post #4332
I then took a look at the new boot and flange. These are also essentially type 1, with 6 bolt holes.
bkrantz
post Dec 14 2021, 08:44 PM
Post #4333
But what I don't like is the sloppy fit. The OD of the outer part of the CV is 90 mm, but the ID of the flange is about 94 mm.
bkrantz
post Dec 14 2021, 08:48 PM
Post #4334
I thought about a stock paper gasket on the inside of the flange, but this would prevent metal-to metal contact of the boot flange and leave some compressibility in the stack.
I ordered some 90/94 mm O-rings to try another way.
bkrantz
post Dec 14 2021, 08:52 PM
Post #4335
Then I got out the trans mounts. More re-plated stuff and new rubber mounts.
bkrantz
post Dec 14 2021, 08:54 PM
Post #4336
I also took the chance to set up the muffler and bracket on the rear of the trans. (And the trans mount bolts are upside down for now.)
bkrantz
post Dec 14 2021, 08:58 PM
Post #4337
This was also a chance to double-check the O2 sensor bung location. It still looks good, since I am not using the stock muffler hanger. But for good sensor clearance the bung needs to be horizontal.
bkrantz
post Dec 14 2021, 08:59 PM
Post #4338
Looks good, so off to the welder.
bkrantz
post Dec 14 2021, 09:01 PM
Post #4339
Final bit for today: bolt on the trans mounts, with the bolts correct (inserted from below).
bkrantz
post Dec 15 2021, 08:21 PM
Post #4340
I got distracted by a few other things today, including shoveling snow.
But I think I have decided where and how to mount the ECU and relay box.
- Lo-Fi Version Time is now: 29th April 2025 - 01:19 PM
