343 Pages V « < 216 217 218 219 220 > »
> Rebuiding Inside-out
bkrantz
post Dec 15 2021, 08:24 PM
Post #4341
The ECU will mount to a plate attached to the trunk wall, and the relay box will piggy-back on top of the ECU. There is enough room to attach serial cables to the right side of the ECU, and the big cable clears the jack.
I also mocked up the position of the O2 signal processor, and the tach signal adapter.
I plan a 1 inch hole for cables to pass into the engine compartment just to the right of the tach adapter.
bkrantz
post Dec 15 2021, 08:26 PM
Post #4342
With my remaining time today, I worked out the connections between all the components. I think I finally have it all sorted.
Puebloswatcop
post Dec 16 2021, 08:41 AM
Post #4343
QUOTE(bkrantz @ Dec 15 2021, 08:24 PM) *
I really like your mounting solution it looks very clean and organized...
bkrantz
post Dec 16 2021, 08:31 PM
Post #4344
QUOTE(Puebloswatcop @ Dec 16 2021, 07:41 AM) *
Thanks--I still like it today, but I will wait to make it permanent until after I get all the wiring done.
bkrantz
post Dec 16 2021, 08:34 PM
Post #4345
More details while I am waiting for parts to finish the engine-trans mating.
I got out the pieces for the shift rod, including new bushings and conical screws.
bkrantz
post Dec 16 2021, 08:36 PM
Post #4346
New bushings pressed into the coupling.
bkrantz
post Dec 16 2021, 08:37 PM
Post #4347
Coupling on the rear rod (and yes, the screw side will face down).
bkrantz
post Dec 16 2021, 08:38 PM
Post #4348
With the rubber boot, ready to install.
bkrantz
post Dec 16 2021, 08:40 PM
Post #4349
A couple of problems I did not notice with the front rod: I installed it "sideways", and did not notice that the powder coating got onto the machined end that inserts snugly into the coupling.
bkrantz
post Dec 16 2021, 08:42 PM
Post #4350
A bit of scraping and sanding, and the rod fits into the coupling.
bkrantz
Post #4351
Back in the car, and roughly aligned.
bkrantz
post Dec 16 2021, 08:45 PM
Post #4352
I forgot to mention that to remove the front rod, I have to open access to the shift lever base and loosen the bolt. I guess I should leave it open until the engine and trans are in place.
bkrantz
post Dec 16 2021, 08:47 PM
Post #4353
Final shift linkage bit, at the trans input. New bushings for the shaft hole and the ball joint.
bkrantz
post Dec 16 2021, 08:50 PM
Post #4354
Finally, the input coupler--more re-plated bling that nobody will see.
nivekdodge
post Dec 16 2021, 09:44 PM
Post #4355
Exquisite
bkrantz
post Dec 17 2021, 09:27 PM
Post #4356
I am trying to do all the things that are easier while the engine in still out. I got out all the trunk hinge parts and torsion bars.
bkrantz
post Dec 17 2021, 09:28 PM
Post #4357
First, I used a die to chase all the studs.
bkrantz
post Dec 17 2021, 09:31 PM
Post #4358
Then I fought the torsion bars into place, and clamped down. These things as a b*tch even at the beginning.
bkrantz
post Dec 17 2021, 09:33 PM
Post #4359
At least I did remember to pass the bars through the hoop bracket. BTW, these are also powder-coated.
bkrantz
post Dec 17 2021, 09:36 PM
Post #4360
Then the hinges, with the lever piece. I used lock nuts on the lever studs.
- Lo-Fi Version Time is now: 29th April 2025 - 08:27 AM
