343 Pages V « < 218 219 220 221 222 > »
> Rebuiding Inside-out
bkrantz
post Dec 18 2021, 09:14 PM
Post #4381
To minimize mess, after installing one CV on each half-shaft, I attached the stub axle with a new paper gasket.
bkrantz
post Dec 18 2021, 09:16 PM
Post #4382
Without my press, I used a vise to squeeze the CV with new locating pins into the flange, enough to get the bolts started.
bkrantz
post Dec 18 2021, 09:23 PM
Post #4383
I then used new factory bolts, with new Schorr washers, and re-plated hardware, and got the stub axles attached.
I then installed the CV on the other end.
bkrantz
post Dec 18 2021, 09:26 PM
Post #4384
Eventually, I had two complete axles, ready to install.
bkrantz
post Dec 18 2021, 09:27 PM
Post #4385
And so, into the rear hubs.
bkrantz
post Dec 18 2021, 09:28 PM
Post #4386
Easy to insert the splined stub axle.
bkrantz
post Dec 18 2021, 09:39 PM
Post #4387
I braced the hub, and then got out the big torque wrench. 30-35 mkp (220-250 ft-lbs) is a big twist.
bkrantz
post Dec 18 2021, 09:42 PM
Post #4388
And then finished with cotter pins.
bkrantz
post Dec 18 2021, 09:43 PM
Post #4389
Ready for engine and trans.
euro911
post Dec 19 2021, 12:25 PM
Post #4390
Paint the rotor hats black to help dissipate the heat. Also keeps rust at bay (IMG:style_emoticons/default/idea.gif)
bkrantz
post Dec 19 2021, 08:09 PM
Post #4391
Thanks for the tip, Mark. I will put that on the list.
bkrantz
post Dec 19 2021, 08:11 PM
Post #4392
I got some 22 G 3-conductor cable. This will connect the O2 sensor control with the AFR gauge.
bkrantz
post Dec 19 2021, 08:14 PM
Post #4393
To get from the frunk to the interior I need to snake the cable through the snorkel. First, a bit of stiff wire.
bkrantz
post Dec 19 2021, 08:15 PM
Post #4394
Then the cable.
bkrantz
post Dec 19 2021, 08:16 PM
Post #4395
And into the interior.
bkrantz
post Dec 19 2021, 08:17 PM
Post #4396
Now to connect the cable to the leads for the gauge. I soldered the connections.
bkrantz
post Dec 19 2021, 08:19 PM
Post #4397
And then heat-shrink tubing around each connection, and around all three.
bkrantz
post Dec 19 2021, 08:21 PM
Post #4398
I think the gauge will live in the center arm rest, next to my hidden audio system controller.
bkrantz
post Dec 19 2021, 08:24 PM
Post #4399
At the other end, I put the snorkel back in place. I will find the best route for the cable when I do all the engine wiring.
bkrantz
post Dec 19 2021, 08:25 PM
Post #4400
Speaking of wire placement, I drilled a 1 inch hole in the trunk wall.
- Lo-Fi Version Time is now: 29th April 2025 - 03:02 AM
