bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
And that means I have to commit to the layout of components in the engine compartment. I have been less than happy with the access to the rear of the right throttle body. The space there is tight enough, and that's where I have all the fuel lines and EFI cables.
So I decided to swap the left and right throttle bodies, so that the accelerator cable pulleys will be on the front side. Attached thumbnail(s) ![]() |
bkrantz |
So I don't have to undo the fuel lines, and swap the angle fittings in the injector rails, I decided to swap the throttle bodies but leave the rails in place. This turned out to be a bit fiddly.
bkrantz |
So I got both rails detached, along with other connections, swapped the throttle bodies, and got the rails re-installed. But now dinner calls.
bkrantz |
Back on task, getting the swap of the throttle bodies done.
bkrantz |
Now the right rear corner is not so crowded.
bkrantz |
But now I have to also switch the throttle position sensor cable (3 prong connector) to the left side, and that will take about 18" more length.
bkrantz |
To do that, I have to pull the right bundle back into the engine compartment, and then pull more of the TPS cable out from the end of the bundle. And before that, I undid all the temporary wire connections at the relay box and elsewhere.
bkrantz |
Once all the lengths were adjusted I snaked the bundle back through the hole and grommet. I will trim back the cable covers and route all the individual wires later.
bkrantz |
Now for the throttle cable. The modified sheet metal hole position still works well.
bkrantz |
With the throttle stops, adjusters, and pulleys on the front side, I have much better access. Should have done it this way to start.
bkrantz |
While I had the chance, I did the rough adjustment to set and sync the left and right throttles. I used a .003" feeler gauge.
bkrantz |
And set the throttle plate gap on both sides. Once the engine is running again, I will balance the airflow.
bkrantz |
With the lower air filter plates and stacks back on, I am caught up to where I started. The engine compartment looks better--and easier.
bkrantz |
Aerial view.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
So "sano" there Bob. Looks like an operating theater at the local hospital. Ha
Super nice! |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,302 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
I love this entire build. (IMG:style_emoticons/default/beerchug.gif)
bkrantz |
bkrantz |
This could be the last white board list. At least when I get all these tasks done the car should be ready for the road.
bkrantz |
An easy job: new oil filter.
bkrantz |
Filter installed, plus a new ring on the drain plug.
Lo-Fi Version | Time is now: 27th April 2025 - 06:06 AM |
