343 Pages V « < 230 231 232 233 234 > »
> Rebuiding Inside-out
Montreal914
post Jan 6 2022, 09:43 PM
Post #4621
Beautiful work and meticulous installation (IMG:style_emoticons/default/smilie_pokal.gif)
What brand of speedometer cable? (IMG:style_emoticons/default/sad.gif)
Morph914
post Jan 7 2022, 09:57 AM
Post #4622
QUOTE(bkrantz @ Jan 6 2022, 10:38 PM) *
I spent almost an hour on this. First I chased the threads, but no luck. Then I used my Dremel to chamfer the first threads in the cap and on the angle drive. I got it started straight, and it held for about two turns--yay! But as I screwed it tight, it cocked twisted again. Fudge!
I will probably hold just fine, but this will bother me and my OCD.
I had the same problem with mine, tried several times with no luck and the same issues as yours. (IMG:style_emoticons/default/headbang.gif) Finally one day I crawled back under held my tongue a certain way, the planets aligned, the Speedo Gods had mercy and the damn thing went on correctly. (IMG:style_emoticons/default/piratenanner.gif) I was so happy for this small issue to be behind me.
So don’t give up on it just yet.
Cheers,
John
ndfrigi
post Jan 7 2022, 10:46 AM
Post #4623
wow! been watching your build and give us encouragement and learned a lot from your detailed informations.
I just want to ask if the bolt/nut for tranny mount is better that the nut is on top or the usual from various 914 that the nut is at the bottom?
Puebloswatcop
post Jan 7 2022, 06:56 PM
Post #4624
QUOTE(bkrantz @ Jan 6 2022, 09:38 PM) *
I am with you on this. I would be awake nights wracking my brain about why it is not going on straight.....
bkrantz
post Jan 7 2022, 08:25 PM
Post #4625
QUOTE(ndfrigi @ Jan 7 2022, 09:46 AM) *
I followed the geometry shown in the factory parts catalog. And with the nut on top, I can remove the bolt without removing the mount--not sure if this will be helpful in the future or not.
bkrantz
post Jan 7 2022, 08:26 PM
Post #4626
QUOTE(Puebloswatcop @ Jan 7 2022, 05:56 PM) *
Gee, thanks. Now I will never sleep. (IMG:style_emoticons/default/blink.gif)
bkrantz
post Jan 7 2022, 08:29 PM
Post #4627
With a few more parts, I am ready to start the "final" wiring for the EFI system. Here the dual bus and cover I got from McMaster-Carr, and some small gauge ring terminals.
bkrantz
post Jan 7 2022, 08:31 PM
Post #4628
I decided on this layout, L to R: the tach signal adapter, the O2 sensor controller, and the double bus.
bkrantz
post Jan 7 2022, 08:33 PM
Post #4629
Now its just one wire at a time, after confirming which wire goes where. I am soldering the terminals on to avoid future problems.
bkrantz
Post #4630
And first connection on the ground bus.
bkrantz
post Jan 7 2022, 08:37 PM
Post #4631
I added some electrical tape along the exposed edge of the relay box, since the wires will hang over the edge.
bkrantz
post Jan 7 2022, 08:40 PM
Post #4632
That's enough for today, with the connections done for the O2 system and the coil.
bkrantz
post Jan 8 2022, 08:04 PM
Post #4633
Just a few more wires run today. The device on the left is the rpm signal converter, with the cover removed.
bkrantz
post Jan 9 2022, 07:40 PM
Post #4634
Tach signal converter all wired up.
bkrantz
post Jan 9 2022, 07:42 PM
Post #4635
So that's all the various boxes and components connected. Now for the cables from the engine sensors.
bkrantz
post Jan 9 2022, 07:44 PM
Post #4636
Whew. After a solid 5 hours, everything is connected. For each cable, I trimmed back the mesh cable cover, then covered the raw mesh end with heat-shrink, and trimmed and tinned each wire end before making the screw connection on the relay board.
Once I confirm that the engine runs again, I will tidy this up a bit.
bkrantz
post Jan 9 2022, 07:46 PM
Post #4637
And here's the waste from shortening the cables.
bkrantz
post Jan 9 2022, 07:47 PM
Post #4638
Another task crossed off.
bkrantz
post Jan 10 2022, 08:36 PM
Post #4639
One last wire had to be resolved, and the Dub Shop schematics did the trick. I am 99% confident I have every connection as Mario designed. (But when my son helped with temporary connections for the first engine start a couple of weeks ago, we had 2 wires from the Hall sensor reversed. Hmm)
bkrantz
post Jan 10 2022, 08:40 PM
Post #4640
With everything connections, I turned the key to Run--no flames or explosions. But since I changed the oil and filter, I want to get oil circulating again.
- Lo-Fi Version Time is now: 26th April 2025 - 09:10 PM
