343 Pages V « < 233 234 235 236 237 > »
> Rebuiding Inside-out
bkrantz
post Jan 15 2022, 08:29 PM
Post #4681
Now the left side. First I modified the horizontal duct so it will insert into the exchanger outlet.
bkrantz
post Jan 15 2022, 08:31 PM
Post #4682
Flap valve modified by rounding the lower corners.
bkrantz
post Jan 15 2022, 08:32 PM
Post #4683
Ducts from the blower housing to the exchanger, and the vertical tube up through the sheet metal.
bkrantz
post Jan 15 2022, 08:33 PM
Post #4684
Upper hole elongated, just like the right side.
bkrantz
post Jan 15 2022, 08:34 PM
Post #4685
Horizontal duct forced into place. Now I just need the left side control box.
bkrantz
post Jan 16 2022, 09:27 PM
Post #4686
Yesterday, the postman delivered another NOS heat control box.
bkrantz
post Jan 16 2022, 09:28 PM
Post #4687
In case I was not sure which side?
bkrantz
Post #4688
So that's where I put it. Upside down?
bkrantz
post Jan 16 2022, 09:33 PM
Post #4689
I need a few more little parts to finish the heat system, so I played with some more stuff that got delivered recently.
Since I need to replace the PCV valve with an open fitting, I tried to find something that fits the holes (outer and inner) in the stock oil breather. It took about 4 tries, but I finally got a fitting (1.2 inch barb and 14x1.5 threads) in aluminum from Racetronix, and a 14x1.5 brass nut from Belmetric.
bkrantz
post Jan 16 2022, 09:34 PM
Post #4690
It fits just right, with a dab of aviation sealant.
bkrantz
post Jan 16 2022, 09:35 PM
Post #4691
Breather re-installed and the vent hoses all connected for real. We will see if this vent scheme works once the car is on the road.
bkrantz
post Jan 16 2022, 09:38 PM
Post #4692
With a bit more time to play, I got down the rear valance. It still looks a bit lumpy but I figure it will not be too visible, and I would rather have the durability of powder coating--which means no filler (and means my limited metal forming skills can't be hidden).
bkrantz
post Jan 16 2022, 09:41 PM
Post #4693
If you recall from 2 years ago, I had to weld in a patch to repair a very home-made PO hole on the right side for his custom dual exhaust. This view is the inside--the outside is not perfect but better.
bkrantz
post Jan 16 2022, 09:42 PM
Post #4694
To install the valence I removed the bumper. No big deal, except...
bkrantz
post Jan 16 2022, 09:47 PM
Post #4695
On both license plate lights, the ground wire terminals were broken. Time to re-do these before the bumper can go back on.
bkrantz
post Jan 16 2022, 09:50 PM
Post #4696
I did get the valence mounted, with a little bit of persuasion since the curve of the restored rear panel does not quite match the valence.
bkrantz
post Jan 16 2022, 09:51 PM
Post #4697
Clearance to the tail pipe is a bit less than 1/4 inch. I want to see if I can enlarge this.
bkrantz
post Jan 17 2022, 07:55 PM
Post #4698
I replaced the ground wire terminals, and stripped back some of the heat-shrink tubing I installed last year so the wires can bend more easily. And then a quick check of the lights--they work!
bkrantz
post Jan 17 2022, 07:56 PM
Post #4699
With the bumper back on the rear end is complete.
bkrantz
post Jan 17 2022, 08:02 PM
Post #4700
I finally got my replacement for the throttle position sensor, from Summit Racing. This is a Ford sensor with a Delphi (GM) plug connector--apparently a relatively common custom EFI part. But the lead positions are not the same as what I had, so I switched them.
- Lo-Fi Version Time is now: 26th April 2025 - 01:20 PM
