bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
And after a bunch of welding and grinding, and more welding and grinding.
Attached thumbnail(s) ![]() |
bkrantz |
With the trunk corners done, I am on to the list of remaining small tasks.
bkrantz |
Headlight box drain tube.
bkrantz |
Bottom side of engine lid hinge mounts.
bkrantz |
Next up, the muffler shield.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Next up, the muffler shield. Bob....mine is removable. Plus I had it ceramic coated to keep the heat out of the rear trunk. Unsure if that worked or not, but the theory was sound. (IMG:style_emoticons/default/wink.gif) I'll have to see if I have pics from my build. But just think....screws to hold the shield to the standoffs. |
bkrantz |
Thanks, Doug. I remember that from your build, and it has me thinking.
bkrantz |
No real work today, but I did look over the body shell again, and found a few more things for the list.
bkrantz |
I got started on the muffler shield. I want this to be bolt on, but no holes in the trunk floor. I removed the 6 original legs and fabricated 2 brackets with bolts welded in as studs.
bkrantz |
Here's the shield with the new brackets bolted on for placement on the trunk floor.
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
bkrantz |
Thanks, me too. The shield sits in the stock location +/- 1/4 inch. And it seems plenty rigid.
bkrantz |
Here is one of the new brackets welded in place.
bkrantz |
Both brackets.
bkrantz |
And the shield bolted on. Done with this and crossed off the list.
Bmw635 |
Member ![]() ![]() Group: Members Posts: 66 Joined: 19-February 20 From: OC, CA Member No.: 23,943 Region Association: Southern California ![]() |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,951 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Here's the shield with the new brackets bolted on for placement on the trunk floor. I really like this idea and glad you made the extra effort to do it this way. (IMG:style_emoticons/default/agree.gif) I've been contemplating best way to do as well. I've been running without it for the last few weeks, but it probably needs to go back on. I like this approach. |
bkrantz |
bkrantz |
I decided to weld the U-holes in the passenger floor. I would rather have the simplicity than the original details.
bkrantz |
And now onto the channel for the weatherstrip around the frunk opening. First, identifying all the rusted segments. These include the front edge (pretty much all on the inner side):
Lo-Fi Version | Time is now: 20th April 2025 - 12:45 AM |
