343 Pages V « < 252 253 254 255 256 > »
> Rebuiding Inside-out
bkrantz
post Apr 16 2022, 08:38 PM
Post #5061
Gauge reading--just barely more than original "null" reading.
bkrantz
post Apr 16 2022, 08:40 PM
Post #5062
More heat.
bkrantz
post Apr 16 2022, 08:41 PM
Post #5063
Much lower resistance.
bkrantz
post Apr 16 2022, 08:43 PM
Post #5064
Finally, some temperature indication.
Now I can swap the new sender for the old one. I guess its time for another oil change. Too bad the car is not on a rotisserie!
bkrantz
post Apr 16 2022, 08:45 PM
Post #5065
I noticed another teaser from my 914: the brake lights were on all the time (with the key on).
bkrantz
post Apr 16 2022, 08:48 PM
Post #5066
Turns out the trigger arm for the brake light switch was under the ring on the piston rod. I guess this happened when I swapped master cylinders.
bkrantz
post Apr 17 2022, 07:32 PM
Post #5067
After draining the oil, I removed the cover to expose the old temp sensor.
bkrantz
post Apr 17 2022, 07:33 PM
Post #5068
And swapped in the new one.
bkrantz
post Apr 17 2022, 07:34 PM
Post #5069
And after a bit of fuss, and a dab of sealant, I re-installed the cover and connected the sensor lead.
bkrantz
post Apr 17 2022, 07:37 PM
Post #5070
The original connector for the oil temp lead (under the battery) finally gave up. The next time I have good access with the engine removed, I will replace it properly. For now I made a temporary repair.
NS914
post Apr 18 2022, 06:12 PM
Post #5071
I cannot thank you enough for the level of detail and fantastic photography throughout this build! Among the many things I have learned, I have found my most recent question answered.....where does that green wire go???? LOL!
So your pictures show it coming up out of the engine bay and I am assuming it goes through the centre tunnel and up to the gauges!
Happy Easter and thanks for all of your work!!!
Grant
NS914
post Apr 18 2022, 06:19 PM
Post #5072
QUOTE(NS914 @ Apr 18 2022, 09:12 PM) *
...and my apologies, I realized I didn't know your first name, well Bob, thanks so much again!
Grant
bkrantz
post Apr 18 2022, 07:59 PM
Post #5073
Thanks, Grant. Glad you found some of this useful.
The green wire for the oil temp ducks into the harness below the battery, joins the other wires that enters the interior via the "snorkel", and comes out of the harness at the center console. It is the single connector between the doubles in the photo.
The console gauge harness then connects these to the gauges. In my car, the gauge harness wire for the oil temp gauge is white.
NS914
post Apr 19 2022, 08:12 AM
Post #5074
Thanks so much Bob! I nice to have easy work in amongst some of the more challenging jobs.
I need to replace the Brake light switch at the pedal and fiddle with the headlights....they are possessed re up and down....lights work though. LOL!
I hope you will not mind but I can see myself reaching out to you again soon...LOL
Grant
bkrantz
post Apr 19 2022, 07:44 PM
Post #5075
Happy to help. The headlights can be a challenge, but you should find some good info around here.
bkrantz
post Apr 19 2022, 07:47 PM
Post #5076
Time to start on the targa top. I should have all the new rubber and hardware I need.
bkrantz
post Apr 19 2022, 07:53 PM
Post #5077
I will have to recycle the old metal strips from the original rear weatherstripping. As many of you know, the short side pieces are bonded to the rubber on the original.
bkrantz
post Apr 19 2022, 07:55 PM
Post #5078
Step 1 is to separate the rubber from the metal.
bkrantz
post Apr 19 2022, 07:57 PM
Post #5079
Then I need to remove the PO black paint. I sure hope these are the last parts I need to restore. For this, I was able to get most of the paint off with my thumb nail.
bkrantz
post Apr 19 2022, 07:58 PM
Post #5080
And I got started on the cross strips.
- Lo-Fi Version Time is now: 24th April 2025 - 09:42 AM
