343 Pages V « < 267 268 269 270 271 > »
> Rebuiding Inside-out
raynekat
post May 30 2022, 11:05 PM
Post #5361
You had me on the ski mount plugs.....
Puebloswatcop
post May 31 2022, 05:44 PM
Post #5362
Bob,
The cover you made looks awesome. I love seeing the solutions you come up with and then make them happen.
bkrantz
post May 31 2022, 08:14 PM
Post #5363
Thanks, Howard. The cover is not done yet. I need to fix it in place. My idea is a velcro patch on the firewall and corresponding spot on the cover. Here's an angled spacer inside the cover to mount the velcro.
bkrantz
post May 31 2022, 08:21 PM
Post #5364
While letting the epoxy set, I got started on suspension alignment. I want to get the settings close enough so I can take the car for a test drive, and make the final alignment less of a chore.
After I measured the camber again all around, I got started on the right rear. With the wheel off, I can finally re-attach the sway bar link.
bkrantz
post May 31 2022, 08:24 PM
Post #5365
Oops, my inner fender liners block access to the outer suspension mount.
bkrantz
post May 31 2022, 08:25 PM
Post #5366
That's better. You can see the original stack of shims: 2 x 4mm, and 2 x 2 mm for a total of 12mm.
bkrantz
post May 31 2022, 08:36 PM
Post #5367
The first camber measurement was -0.1°. I want something like -0.75° all around. So I removed one 4mm shim. That dropped the camber right on target to -0.75° (and I noted that each 1mm of shim stack change is about 0.15°).
bkrantz
post May 31 2022, 08:44 PM
Post #5368
Same process on the left side, but to get the sway bar link aligned, I had to lift the trailing arm.
bkrantz
post May 31 2022, 08:45 PM
Post #5369
Here's the original shim stack on the left side, a 2, 3, and 4 mm for a total of 9mm.
bkrantz
post May 31 2022, 08:48 PM
Post #5370
Two 4mm shims decreases the shim stack by 1mm. That got the measured camber to -0.75°.
bkrantz
post May 31 2022, 08:52 PM
Post #5371
Then I got started on the front. The top of the left strut is easy to access.
bkrantz
post May 31 2022, 08:54 PM
Post #5372
The original camber measured -0.3°, so I shifted the strut top inward about 4mm.
bkrantz
post May 31 2022, 08:55 PM
Post #5373
That got the camber to about -0.7° on my high-tech gauge.
bkrantz
post May 31 2022, 08:59 PM
Post #5374
Of course, the right strut top is blocked a bit by the evaporator tank.
bkrantz
post May 31 2022, 09:03 PM
Post #5375
Tank detached enough to get to the inner bolt.
The original camber measured -0.85°. When I shifted the strut top out as far as it goes, I got -0.6°, and then I moved it back inward to get about -0.7°.
Next up: some rough toe setting.
bkrantz
post Jun 1 2022, 08:09 PM
Post #5376
Oops, I lied. Instead of working on toe settings, I worked on soft stuff. First, here is the velcro on my EFI brain cover, and the trunk wall.
bkrantz
Post #5377
The cover seems pretty well attached.
bkrantz
post Jun 1 2022, 08:11 PM
Post #5378
I also got more door card parts delivered. I now have a variety of pins and cups.
bkrantz
post Jun 1 2022, 08:13 PM
Post #5379
For future reference, the original white pins (and the URO copies) are longer. The black pins, and both the clear and black cups, all from 914 Rubber, are shorter.
I went ahead with the short black pins and cups.
bkrantz
Post #5380
Pins in the right door card.
- Lo-Fi Version Time is now: 23rd April 2025 - 01:13 PM
