bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
With the frunk channel done, I switched to the read panel. This was the last bit of bodywork with significant filler (than know of--knock on wood).
Here's the panel before grinding off the filler. Attached thumbnail(s) ![]() |
bkrantz |
And after.
bkrantz |
Some dents and dings, and holes from the PORSCHE reflector panel installed by a PO.
bkrantz |
The reflector panel holes will get welded, and the stock holed for the original insignia will get cleaned of bondo.
bkrantz |
For access to the inside of the panel, I removed the trunk lock mounting plate.
bkrantz |
Here's the mounting plate. Pretty lumpy.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Here's the mounting plate. Pretty lumpy. Hey, I like my smashed pototos lumpy. (IMG:style_emoticons/default/rolleyes.gif) Looking good there Robert with all your progress. |
bkrantz |
Here's the mounting plate. Pretty lumpy. Hey, I like my smashed pototos lumpy. (IMG:style_emoticons/default/rolleyes.gif) Looking good there Robert with all your progress. Thanks, Doug. Still thinking positive here, lumps and all. |
bkrantz |
For better access I unbolted the rotisserie rear upright, with the car on jack stands.
bkrantz |
Now I can see the worst spots.
bkrantz |
And this.
bkrantz |
I propped the trunk lid in place, to compare alignments. The lid has its own issues, including a dip along the trailing edge.
bkrantz |
Right side looks pretty good.
bkrantz |
Left side not so great. The problem is mostly a "droopy" lid edge.
bkrantz |
I worked more today to get things "straight": the top and bottom of the raised boss, and the top edge of the rear panel.
After some moderate metal work, things looked a little better. Attached thumbnail(s) ![]() |
bkrantz |
Eye-balling along the lower edge of the boss. Ignore all the lumps for now.
bkrantz |
Watching the angles.
bkrantz |
When things where looking nearly straight by eye, I rigged up my long level as a reference line. Looking pretty good, with a variance of about 1/16 inch.
bkrantz |
But the trunk lid has its own problems, especially along the rear edge.
bkrantz |
As I started to work the trunk lid edge, I heard a crunch, and my rust-free lid suddenly had a rust-trough hole. Damn. (See my other thread asking for advice)
Lo-Fi Version | Time is now: 20th April 2025 - 05:38 AM |
