343 Pages V « < 270 271 272 273 274 > »
> Rebuiding Inside-out
bkrantz
post Jun 4 2022, 08:12 PM
Post #5421
Windshield installation, Step 1: clean the channel with adhesive remover.
bkrantz
post Jun 4 2022, 08:13 PM
Post #5422
Step 2a: mask the channel.
bkrantz
post Jun 4 2022, 08:14 PM
Post #5423
Step 2b: paint the channel with butyl primer.
bkrantz
post Jun 4 2022, 08:15 PM
Post #5424
Step 3: clean the glass, especially the edge that will contact the butyl.
nivekdodge
post Jun 4 2022, 09:28 PM
Post #5425
You have started it, correct? Does the dynamat work or does everyone do it because, everyone does it?
barnfind9141972
post Jun 4 2022, 11:19 PM
Post #5426
QUOTE(nivekdodge @ Jun 4 2022, 08:28 PM) *
@nivekdodge yes it works great, adds a little weight but definitely improves road noise and for me the best improvement was the doors. They went from tin can to super solid, I have a two 6.5 speakers and a 8 inch subwoofer on top of msds headers and no weird vibrations or tons of noise or reverb
nivekdodge
post Jun 5 2022, 04:49 PM
Post #5427
QUOTE(barnfind9141972 @ Jun 5 2022, 01:19 AM) *
Thanks, you never hear if it works or not
Kevin
bkrantz
post Jun 5 2022, 08:12 PM
Post #5428
QUOTE(nivekdodge @ Jun 4 2022, 09:28 PM) *
Do you mean starting the engine? So far only in the garage, so I can't swear that my firewall system works . On the inside, starting from the painted firewall I have Dynamat, Dynaliner, and perlon carpet. On the engine side I have a layer of foil backed with insulation. I do know that I can thump on the firewall and the sound does not resonate though.
bkrantz
post Jun 5 2022, 08:16 PM
Post #5429
Here's the windshield after painting the butyl primer with the masking tape removed.
bkrantz
post Jun 5 2022, 08:22 PM
Post #5430
Next, I fitted the lower (inside) windshield seal.
bkrantz
post Jun 5 2022, 08:24 PM
Post #5431
I notched the ends so they tuck under the bottoms of the A-pillar pads.
bkrantz
post Jun 5 2022, 08:25 PM
Post #5432
Like this. Note that I had to remove this strip during the installation of the windshield trim clips.
bkrantz
post Jun 5 2022, 08:27 PM
Post #5433
Next I got out the windshield trim kit. This contains the 3 sections of the trim plus all the small pieces.
bkrantz
post Jun 5 2022, 08:29 PM
Post #5434
The small pieces include another batch of (aftermarket) plastic retaining clips, rubber spacers, and 3 aluminum trim junctions. Note that I plan to use the factory clips since I have read they are more robust and reliable.
bkrantz
post Jun 5 2022, 08:36 PM
Post #5435
I also dry-fit the trim. As others have said, this stuff is VERY flexible. Thats good since I had to do some gentle bending on all 3 pieces.
bkrantz
post Jun 5 2022, 08:37 PM
Post #5436
Step 4: OK, time for the retaining clips. I had one spare of the factory clips.
bkrantz
post Jun 5 2022, 08:38 PM
Post #5437
My method: first dip the prongs into some soapy water.
bkrantz
post Jun 5 2022, 08:41 PM
Post #5438
Then use a 5mm 1/4" socket on an extension and soft mallet to tap the prongs into the hole.
bkrantz
post Jun 5 2022, 08:43 PM
Post #5439
And then seat the plastic stud with a pin punch. Easy, right?
bkrantz
post Jun 5 2022, 08:45 PM
Post #5440
But my first attempt failed. I hit the clip too hard (and probably unevenly) trying to seat the prongs, and the clip split. After that, I had no spares.
- Lo-Fi Version Time is now: 23rd April 2025 - 07:39 AM
