343 Pages V « < 29 30 31 32 33 > »
> Rebuiding Inside-out
bkrantz
post May 4 2020, 08:26 PM
Post #601
And I took a quick look at the rear panel. More work to do.
BeatNavy
post May 5 2020, 04:42 AM
Post #602
Ok, that helps fill in the gap, thank you! I've got a small version of one of those profile gauges, but nothing like that for car body work. The tool whore in me may need to acquire one of those.
Appreciate it (IMG:style_emoticons/default/beer.gif)
bkrantz
post May 5 2020, 09:42 PM
Post #603
Never enough tools!
https://www.amazon.com/gp/product/B001C06BB...=UTF8&psc=1
bkrantz
post May 6 2020, 08:00 PM
Post #604
First job today was to weld up the "extra" holes in the rear panel, and then give it another pass of metal work.
bkrantz
post May 6 2020, 08:03 PM
Post #605
I then gave the other panels another smoothing pass. I might be getting these as good as I can. The photos might not show that the highs and lows differ by only about a mm or less.
Front left
bkrantz
Post #606
Front right
bkrantz
post May 6 2020, 08:04 PM
Post #607
Left cowl
bkrantz
Post #608
Right cowl
bkrantz
post May 6 2020, 08:06 PM
Post #609
And I made a first check of the right rear fender. More work to do here.
bkrantz
post May 7 2020, 08:20 PM
Post #610
I took a break from panel work today. The first task was replacing a broken stud for the trunk lid torsion bar bracket on the right side. The PO repair was a hole drilled and tapped "nearby".
bkrantz
post May 7 2020, 08:22 PM
Post #611
First step was to cut off the remains bit of stud, and then drill through the flange inside the long.
bkrantz
Post #612
Then I tapped the new hole (M8 x 1.0).
bkrantz
post May 7 2020, 08:23 PM
Post #613
Here's the new stud screwed in place.
bkrantz
post May 7 2020, 08:24 PM
Post #614
And then tack-welded (along with the PO hole) and ground down to accept th bracket.
bkrantz
post May 7 2020, 08:26 PM
Post #615
Next, I went to work on the trunk lid. As I previously reported, this replacement lid had a rust-through in the inner rib along the trailing edge. I had cut out the rusted section and cleared out some of the inner foam.
bkrantz
post May 7 2020, 08:28 PM
Post #616
Today, I went after more of the foam. I managed to clear it from the side with the access hole and through the center latch area.
bkrantz
post May 7 2020, 08:29 PM
Post #617
I broke out the bore scope to see the degree of rust and remaining foam.
bkrantz
post May 7 2020, 08:31 PM
Post #618
Here's a shot from inside the space between the rib and the trunk lid skin. Looks like the worst rust is where I cut out the original spot. But still lots of foam to extract from the other side.
raynekat
post May 7 2020, 10:06 PM
Post #619
QUOTE(bkrantz @ May 7 2020, 07:31 PM) *
Now that's something you don't see everyday!
The "money" shot.
Well done there Bob.
Kansas 914
post May 8 2020, 08:32 AM
Post #620
I wonder if there is a chemical that would "eat" the foam and not damage the metal?
- Lo-Fi Version Time is now: 20th April 2025 - 07:04 AM
