bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
And I used a puller to take off the blower hub.
Attached thumbnail(s) ![]() |
bkrantz |
I finally drained the oil. This was the second fill after startup.
bkrantz |
And with the cross bar and engine mounts, I could access the pump.
bkrantz |
Pump cover off.
bkrantz |
After some more investigation, as reported on my other thread about oil leaks, I can say (with embarrassment) that the oil filter was loose and probably responsible for much of the leaked oil.
One other culprit might be the pump cover. I want to make sure the mating surface is flat. So I got out my new reference flat: a piece of machined aluminum plate. I got this at one of my favorite stores, Industrial Metal Supply, in Tucson. They sell just about any type and grade of metal, including aerospace stuff. They also have a room of cut-off pieces, sold by the pound. I paid something like $30 for this machined plate. It has a few scratches, but will serve this purpose. Attached thumbnail(s) ![]() |
bkrantz |
Here's the cover, cleaned up and old sealant removed. You can see some uneven scoring from the pump gear.
bkrantz |
To check the cover flatness, I sprayed the mount surface with flat black.
bkrantz |
800 grit paper on the aluminum.
bkrantz |
Some light sanding shows that two corners are high.
bkrantz |
I got out some 400 grit paper, to start making the cover flat.
bkrantz |
First round of sanding, and the cover sure looks uneven, and especially high from lower left to upper right.
bkrantz |
After about 30 minutes, but still not quite even. But time for dinner.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,047 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I would bet there is a probability for leakage at the pump cover. How much out of whack would you estimate the cover was? It looks as though it is stamped steel with rolled edges.
A loose filter could also create some mess. Thanks for the investigative work |
bkrantz |
I would bet there is a probability for leakage at the pump cover. How much out of whack would you estimate the cover was? It looks as though it is stamped steel with rolled edges. A loose filter could also create some mess. Thanks for the investigative work Yes, stamped steel with folded edge, and then machined. But certainly not flat when installed. |
bkrantz |
More 400 grit. Not perfect but getting tired, so good enough? (IMG:style_emoticons/default/confused24.gif)
bkrantz |
Then 800 grit.
bkrantz |
And 1000 grit. Shiny and ready.
930cabman |
With a very thin paper gasket?
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,443 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Hoping that after all of the detective work and manual labor this is the solution......
bkrantz |
Lo-Fi Version | Time is now: 21st April 2025 - 02:03 PM |
