| bkrantz |
Jan 28 2023, 07:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,552 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
My first support design. I figure something like this should damp vibrations enough. This is easy since I don't have a distributor.
Attached thumbnail(s) |
| bkrantz |
Jan 28 2023, 07:55 PM
Meanwhile, I got a new oil seal (and spare) for the crank end. These are Erling, for those keeping score.
| bkrantz |
Jan 28 2023, 07:56 PM
I popped out the old seal, and discovered another potential leak.
| bkrantz |
Jan 28 2023, 07:57 PM
The case seam in the seal recess is not even at the bottom. You can see a small raised edge, that is obvious by feel. The top is fine.
| bkrantz |
Jan 28 2023, 07:58 PM
About 10 minutes with some 600 grit sand paper.
| bkrantz |
Jan 28 2023, 07:59 PM
Now the recess is even across the seam.
| 930cabman |
Jan 29 2023, 07:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,367 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| bkrantz |
Jan 29 2023, 10:35 PM
The case seam in the seal recess is not even at the bottom. You can see a small raised edge, that is obvious by feel. The top is fine. Axially? I am not sure if I would be concerned with this. Did you get the oil pump straightened out? Yes, the offset was axial. I was concerned that the small step would keep the rubber on the outside of the seal from seating in full contact and could weep oil. |
| bkrantz |
Jan 29 2023, 10:37 PM
Time to start putting things back together. First I dressed the outside sealing surface of the fan hub with some 800 grit.
| bkrantz |
Smooth.
| bkrantz |
Jan 29 2023, 10:39 PM
Then I got the seal ready to install, with a bit of grease on the sealing lip.
| bkrantz |
Jan 29 2023, 10:40 PM
Then a couple of dabs of gasket sealant in the seal recess on the case seams.
| bkrantz |
Jan 29 2023, 10:41 PM
Turns out my PVC pipe wheel cap tool is the right size for seating the seal.
| bkrantz |
Jan 29 2023, 10:43 PM
Seal fully seated and bottomed out against the internal recess.
| bkrantz |
Hub with a bit of grease.
| bkrantz |
Jan 29 2023, 10:47 PM
Torquing the hub retaining nut to 3.2 m-kg.
| bkrantz |
Jan 29 2023, 10:48 PM
With a big screwdriver in the flywheel teeth to hold the crank in place.
| bkrantz |
Jan 29 2023, 10:49 PM
Next the oil pump cover.
| bkrantz |
Jan 29 2023, 10:50 PM
A thin smear of sealant on the gasket.
| bkrantz |
Jan 29 2023, 10:51 PM
Both sides.
Lo-Fi Version | Time is now: 14th December 2025 - 04:58 AM |
