bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,951 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Is that the same foam used in the body above tail lights (and in sail panel)? I think @ClayPerrine recommends just spraying brake cleaner on it. He says that dissolves it pretty nicely. At least I think it was brake cleaner.
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Not sure. The foam in the trunk lid rib is yellow, very rigid, and somewhat porous. What I dug out of one rear fender is white, slightly flexible, and rubbery.
bkrantz |
In any case, I made a foam scooping and pulling tool out of a piece of 1/4 inch steel rod. Stiff enough to work but bendable to change the angle of the "head" inside the rib.
Attached thumbnail(s) ![]() |
bkrantz |
After a couple of hours:
bkrantz |
I got 99% of the foam. And the rust looks minimal.
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,342 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Some brake cleaners may work to dissolve foam, but there are various formulations.
Generally acetone is effective for dissolving most plastics and foams. It is readily available at big box stores. Never really tried it on Porsche foam. Also very rough on paint. Use carefully. |
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,839 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I don’t know how I missed this thread, maybe the title threw me off.
Just read it to here. FANTASTIC WORK. I’ll be following now. Awesome that your son is involved too. Look forward to more. Cheers |
bkrantz |
Thanks, Dion. Doing the work, and the documentation, keeps me going.
bkrantz |
Speaking of foam, has anyone replaced the foam in the trunk lid rib? With what?
bkrantz |
More work on the trunk lid today. Here's the hole cleaned up.
bkrantz |
The patch requires a double curve, one sharper and one constant radius. I got pretty close.
bkrantz |
Fit in place.
bkrantz |
Tack-welded in place. The thin metal around the edge of the hole behaved better than expected.
bkrantz |
And all welded in place. Grinding tomorrow.
bkrantz |
I also welded a small crack in the rib along the right side.
bkrantz |
And I welded two holes in the middle of the trunk lid skin, probably from a luggage rack. I guess that was a thing at some time.
bkrantz |
Got back to work on the trunk lid today. Grinding down the luggage rack holes I filled:
bkrantz |
Grinding down the crack welding in the right side rib:
bkrantz |
And grinding down the welding around the patch. I am pretty happy with this one.
Lo-Fi Version | Time is now: 20th April 2025 - 10:04 AM |
