bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Enough engine (and exhaust) for today.
A whole new task: the speedometer. Both odometers did not work, and the speed reads about 5-6 mph too high. Attached thumbnail(s) ![]() |
bkrantz |
Somebody has had this open before! The retaining ring edge looks a bit rough.
bkrantz |
I did the usual gentle prying round and round, until the ring came off.
bkrantz |
I did notice these marks on the dial. Reference marks for calibrating the needle?
bkrantz |
Remove two screws on the back...
bkrantz |
And out comes the gauge guts.
bkrantz |
My odometer had the typical problem: the drive comes into the gear on the left side of the upper (main odometer) shaft.
bkrantz |
And eventually reaches the pot metal gear on the right end of the number wheels. The metal wheel then drives the ones-digit number wheel, as well as the trip odometer. But the metal gear lost grip on the shaft and does not turn as the shift is driven.
bkrantz |
For access, I removed the speedometer drive module. Just 2 more screws.
bkrantz |
Then I removed the secondary shaft and the small gears that drive the number wheels. That shaft was crimped on both ends, so it took some work to reduce the crimp on one end.
bkrantz |
Secondary shaft and small gears.
bkrantz |
The main shaft pulled out easy, since the metal gear had no grip.
bkrantz |
All the main odometer parts.
bkrantz |
Here's the end of the shaft with marks from spinning in the gear.
bkrantz |
To make a "permanent" grip and fix, I first used my side-cutters to make some ridges on the end of the shaft.
BTW, I kinda over did the ridges, and had to sand the shaft down a bit to fit through the hole in the side plate. Attached thumbnail(s) ![]() |
bkrantz |
Then I deformed the hole in the metal gear with some gentle punches.
bkrantz |
Perfect! It took gentle hammer taps to seat the shaft in the metal gear. Now the gear turns with the shaft.
bkrantz |
Then the secondary shaft the the small gears. I spun the input shaft and everything seems to work.
bkrantz |
That takes care of the odometer. Next up, the speedometer re-calibration. Does anyone know if the needle is a press fit? I tried to pry gently, and it seems stuck.
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,297 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Amazing- I believe the needle is a press-fit, if I am recalling my conversation with Hartmut at Palo Alto Speedo correctly. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 20th April 2025 - 10:14 AM |
